Old 10-05-2015, 02:02 PM   #1
1989 32' Excella
Sharon Springs , New York
Interior floor rot question
Bought a 1989 Excella which had few years old floor repair in the rear (based on the age of the plywood) and looked well done. However, I found a soft spot(turned into a rotted through spot) in the floor about the size of a 9" paper plate in the back corner near the refrigerator side of the kitchen cabinet. The refrigerator was replaced in 2007 and the floor rot itself was dry and crumbly. Is this a spot that is prone to condensation moisture? I plan to repair it but I'd like to get ideas on whether it may be a refrigerator drainage issue or a shell/window leak. Haven't found any other soft spots and the unit doesn't smell musty. Any info on floor rot issues near the fridge would be appreciated...
Regards,
James
Easyrider06 is offline   Reply With Quote
Old 10-06-2015, 08:05 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
In very general terms, it seems that when it comes to rotting floors the area just behind/beneath the refrigerator is a rot prone area. For those older trailers that have a hole in the subfloor for air to circulate up past the back of the fridge, I would assume the rot is due, at least in part, to water splashing up from beneath. There is also usually an access hatch in the exterior wall just behind every fridge, and when the seals dry out and crack, these are as prone to leak as any window. You may alos have leakage from the ceiling "chimney" penetration, that gets funneled down to the floor on the backside of the fridge.
So short answer to your question, I suppose is "all of the above, and then some." Condensate could be a culprit as well, but I would guess it is a minimal contribution. I have a small freezer in my garage (in Houston, TX), and have never observed condensate on the outside of the unit, even on the most humid days.
good luck!
Old 10-06-2015, 08:22 AM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
As Beleg stated, water got in there somehow... Many times.
RV fridges don't have condensate as they are not "frost free". However, if it does frost up and is improperly installed, water could leak in the area.
You need to fix the floor... So a couple pics would help.
Peace and Blessings..
Channing
WBCCI# 30676
« platform bed | Top | tanks »
how much rot is too much rot? adwriter73 Repairing/Replacing Floor &/or Frame 56 02-28-2010 11:05 PM
Hypothetical....How Do I Inspect a Used trailer for Floor Rot prior to making an Offe route66 Repairing/Replacing Floor &/or Frame 13 02-07-2006 08:18 PM
To rot or not to rot. Charming Wino Repairing/Replacing Floor &/or Frame 15 03-01-2004 10:39 PM
repairing floor rot danesh Repairing/Replacing Floor &/or Frame 18 02-03-2004 09:34 PM
Floor Rot mmeburges1 Repairing/Replacing Floor &/or Frame 3 01-10-2004 06:21 PM
