Old 07-18-2011, 08:21 AM   #1
2vets's Avatar
1960 24' Tradewind
St. Albans , Vermont
Exclamation Interior endcap installation
This weekend we were at the stage of installing our endcaps and we invited my sister and brother-in-law over to help us. (new floor/new rebuilt frame by Colin Hyde) We had visions of installing the entire interior skins in one weekend. What a joke! The endcaps damn near defeated us. It took us a day and a half to put in the two endcaps. The holes in the end caps would not line up with the interior ribs. Even beer didn't help us! The final key was to wedge in 2 x 4s to push the interior skin in place and even that was a bear. I am never removing those endcaps again. Period. This is an official announcement that endcap re-installation is WAY harder than you think it will be!!
ID:	135189   Click image for larger version
http://1960airstreamtradewind.blogspot.com
Love. You can learn all the math in the 'verse... but you take a boat in the air that you don't love... she'll shake you off just as sure as the turn of the worlds.
2vets is offline   Reply With Quote
Old 07-18-2011, 08:46 AM   #2
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
We know you & yours suffered terribly and wish to put this matter in the 'win' column and move on...
But would you do "we-the-about-to" a favor and spell out the nuances of how you'd painlessly coax the end-caps into position today if you had another set to install?
I get the warm'n fuzzies looking at the blue-cloud fluff, thats for sure!
Old 07-18-2011, 09:10 AM   #3
2vets's Avatar
1960 24' Tradewind
First, level the trailer if it is not already level. One of the keys is to cleco at the middle of the window and work outwards but do not necessarily cleco the sides of the window to allow for "wiggle room". We then had to milk the top of the skin forward using pressure by either pushing with our hands or by pressing with the 2 x 4s covered with rags. Depending on the area we worked on we would shift the 2 x 4s. We found it best if you can place a cleco centrally on the ceiling and then work down from there (after placing the clecos in the top line of the window) on either side. Make sure you have several sizes of clecos..some of the holes in the fiberglass were bigger than others. There was nothing easy about this job...some of the clecos were under tension and would POP out at us when we were pushing on the interior skin. At first we thought we had used too much insulation (1/2 of R-13 that we split) but we don't think that is the case. We were trying to line up 50 year old holes after a frame restoration..it took a lot more muscle than we thought it would....you had to REALLY push on the skin to get in back in place while someone with a cleco was standing by to throw it in the proper hole. Much swearing took place!!!
Old 07-18-2011, 09:40 AM   #4
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Just went through that a few weeks ago. Did the rear one by myself but took three to do the front one. I think the front one was harder because it is less flexible due to the cabinet opening.
SilverHoot is offline   Reply With Quote
Old 07-18-2011, 11:44 AM   #5
Splitrock's Avatar
Sioux Falls , South Dakota
I only had the rear endcap out of mine. I removed it myself and installed it myself with no problems. All the holes lined up. I installed two 2" sheet metal screws in the bottom two holes so the cap could set on the screws. That raised it about 1/2". There was that much flex. Then I just started installing top rivets. Once I got four rivets installed, I removed the bottom two screws and installed rivets in their place.
Old 07-18-2011, 11:52 AM   #6
2vets's Avatar
1960 24' Tradewind
Wow .. you guys had a much easier time than I did. Was yours a shell off restoration like mine was?
Old 07-18-2011, 11:58 AM   #7
Splitrock's Avatar
I just removed the endcap to remove a dent in the outside skin. My third hand was a load stabilizer jack, but I didn't need it to install the cap.
Old 07-22-2011, 07:29 PM   #8
reinergirl's Avatar
Hollis , New Hampshire
Actually the older trailers have fiberglass endcaps and the later ones had abs plastic which I suspect is much more flexible (and lighter?)
I also think that my sisters trailer, because it was a shell off restoration, had shifted quite a bit.
I'm here to say I'd rather birth another child than do that again. And quite frankly having my kids was faster too!!!
Anyway, I blogged about the process, see my signature. And I'm hereby confessing that my sister doesn't know everything that happened that day.
Hey Sis, read my blog for ....the rest of the story LOL
reinergirl is offline   Reply With Quote
Old 07-23-2011, 06:57 AM   #9
SilverHoot's Avatar
1967 24' Tradewind
I don't know when they changed to plastic, but was still fiberglass in 67.
Old 07-24-2011, 04:52 AM   #10
1977 31' Sovereign
Manchester , New Hampshire
Images: 33
I agree never ever will I remove the end caps in my Airstream again. It took 8 or 9 times for two us to line up holes still got a stress crack in front end cap. Is there a easier way to do that?
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
Mrcrowley is offline   Reply With Quote
Old 07-24-2011, 06:30 AM   #11
Baltimore , Maryland
You folks have me laughing...
I know the struggle. I have been there. Once you learn the trick, it is one handed holding and one handed cleco tooling.
To NOT remove the end cap in NOT a very good idea. I always find many leaks under there.
Cowboy up or take it to a professional. I can recommend a great shop within 650 miles of 65% of the American population.
Old 07-24-2011, 06:52 PM   #12
reinergirl's Avatar
Are you teasing us? What's the trick? Because the board method won't work for my trailer, I have an upper fiberglass built-in cabinet in the front endcap.
Old 07-24-2011, 07:27 PM   #13
I give away a lot of free advice. This one is staying under wraps(job security), but I will say, it all about the dangle of the angle.
Old 07-24-2011, 08:40 PM   #14
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
I gotta say that I agree i'd rather have another child than put another end cap in. Having a 6ft 5in son in law to help was key with the rear one. Front went better but was smaller too. I think 62 overlander is pulling our collective leg!
kay
Hot Water Radiant Heat - My Installation malconium Plumbing - Systems & Fixtures 82 01-30-2012 01:40 PM
Buyer Beware, Bad A/C installation barender Furnaces, Heaters, Fireplaces & Air Conditioning 6 05-23-2011 10:55 AM
composite flooring bathroom installation sealing the toilet handn Floor Finishes 1 03-10-2011 06:47 PM
