Old 11-18-2010, 10:47 AM   #1
H. Green
hazelgreen's Avatar
1991 25' Excella
Edmond , Oklahoma
Interior End Caps in 1991 25' Excella
We have a twin bed model and I noticed that there are hairline cracks stemming from the riveted edge. Is this normal for these later trailers. We have always had older Airstreams and got this one this summer. It is in great condition but have noticed these. It appears these endcaps are plastic but I'm not sure. The cracks all start at the edge and not necessarily from the rivet and are only 1/2" to 1" long. Does anyone have this same problem?
hazelgreen is offline   Reply With Quote
Old 11-18-2010, 03:11 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I have a '74 Argosy 26' with similar cracks. Yours is a lot newer than a '74 and mine is still hanging in there. Other than looking like a problem, I doubt it will fall off. Mine's been hanging there for 36 years. As far a I can tell it is ABS plastic. I believe any thing you try to repair it with will crack as well; between the plastic getting brittle and the natural twisting of the trailer when on the road the cracking is unavoidable.
Old 11-18-2010, 03:46 PM   #3
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
The cracks in mine, the '83 Excella, are 6" or so long. None in the fiberglass endcaps in the Trade Wind. The change to plastic was definitely not an improvement.
Vaughan
Old 11-18-2010, 07:38 PM   #4
H. Green
hazelgreen's Avatar
1991 25' Excella
Edmond , Oklahoma
It is more disappointing than anything as I was so excited about finally getting an Airstream that wasn't a 72 or 73 model and with the rear twin beds. I noticed that the older trailers definitely were built better interior wise but love this trailer and just want to stay on top of everything. I thought if anyone else had the same problems, were they doing anything to keep it from happening further. Thanks for all of the replies.
Old 11-19-2010, 12:03 AM   #5
shelocta's Avatar
1990 25' Excella
Pflugerville , Texas
If it's ABS it will crack! There is a ton of info on the forum about this. Here is the first two that I've found.
http://www.airforums.com/forums/f39/...rts-30510.html
http://www.airforums.com/forums/f39/...air-62688.html
Search for end cap cracks and as was noted many times, drill a small hole at the end of the cracks right away to keep then from propagating.
Good luck
Bill
Give me 40 acres and I'll turn this rig around.
shelocta is offline   Reply With Quote
Old 11-19-2010, 04:13 AM   #6
Davis's Avatar
1996 34' Excella
Americus , Georgia
I have a 34ft 1991 Excella and have noticed in the past year the small cracks have started at the corners of the cabinets in the rear end cap. I was told years ago to stop a crack you would need to drill a small hole at the end of the crack to try and stop it .So far mine have not spreaded any farther. Good luck
1991 Airstream Excella 1000 34ft (SOLD)
1994 Chevrolet Crew Cab dually 2WD 6.5td
2005 Chevrolet Suburban LT 1500 2WD 5.3
WBCCI # 10219 Georgia Unit
AIR # 5131
Davis is offline   Reply With Quote
Old 11-19-2010, 08:33 AM   #7
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
I have some cracks in my '90 Excella 34' end caps as well, front and rear. I have owned the trailer for 3 years now, and they are about the same size as when I bought the trailer. I pointed them out to P&S when I dropped off the trailer this fall, and they have seen it over and over again. I am going to consider it part of the "patina", and not worry about it.
One other point, the end caps yellowed over time. The PO had new drapes made for the entire trailer, the really good ones, and chose "gold" color. It ends up matching the end caps, so I do not need to concern myself with the yellowed end caps, they match.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 11-19-2010, 09:31 AM   #8
H. Green
hazelgreen's Avatar
1991 25' Excella
Edmond , Oklahoma
Thanks for the link to the discussions on this. I go through these forums often but get easily side tracked on other topics. My end caps looks perfect except for the cracks and are not a solid color. I will have my husband read them and will get to work on them as I was amazed how many there are in the rear end cap and very short but starting at the edge closest to the ceiling. Most of those have come on from sitting since our trip this summer. Thanks again for all of the suggestions. I'm glad I am not the only one experiencing this as I was afraid after reading the forums that there might be more to it.
Interior End caps PreacherMan General Interior Topics 1 03-06-2010 06:55 PM
Interior End Caps bill.johnson Floor Finishes 4 09-26-2009 10:08 PM
stripping interior end caps goransons Upholstery, Blinds, Walls & Interior Finishes 6 12-21-2008 08:46 PM
Interior end caps IndyAnne 1959-69 Tradewind 8 09-07-2008 10:17 AM
interior plastic end caps catson4 Interior Restoration Forum 1 01-05-2008 06:30 AM
