Old 05-07-2016, 06:44 AM   #1
1975 Argosy 22 Rear Door
Waterloo , Ontario
Cool Interior end cap crack
I have an argosy and the end cap above the front windows has a straight line crack in it. I want to change the colour but want to cover the crack first. Any suggestions would be greatly appreciated. The material has a plastic feel to it.
Vamethyst is offline   Reply With Quote
Old 05-07-2016, 09:13 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
I had a small hair line crack on either end of the cabinets in the end cap.
Before you change the color of the cap you will have to repair the crack in such a way that it does not just reappear. I removed the cabinet and fiber glassed the back side o the crack. While the patches of fiber glass were small, about 3 x 5 in. I used a couple of layers to be sure of structural strength across the crack. If you can get to the back of the crack consider this approach. If you can not and are going to paint the end cap you could do the repair on the surface if you know how to work with fiberglass and body filler.
2004 Excursion 4x4
Old 05-08-2016, 10:11 AM   #3
Waterloo , Ontario
Thanks. That is what I will have done.
Interior End Cap ? Davis General Interior Topics 2 06-01-2010 05:04 AM
interior end cap removal Leaky 29 General Interior Topics 7 05-26-2010 01:23 PM
Interior end cap fixes... Silver Bullet General Interior Topics 26 07-21-2009 06:17 PM
Interior End Cap Removal: HELP! sierrajb Member Introductions 6 02-02-2006 02:19 AM
Interior End Cap mjohnson63 General Interior Topics 4 04-07-2004 06:34 PM
