Old 09-21-2011, 10:44 AM   #1
Images: 18
Interior ceiling access panel
I was wondering if anyone ever thought of or tried cutting the interior center of the ceiling, running the length of the trailer out and replacing with some type of removable panel? The advantage being access to light fixtures, ac ducting, wiring etc.
yve79 is offline   Reply With Quote
Old 09-21-2011, 01:50 PM   #2
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Drilling a few rivets is about as removable as that center ceiling panel should get, the riveted inner and outer layer of aluminum makes a working part of the whole structure that keeps everything rigid.
Rivets are quite friendly for quick access; drill, access, pop and forget... its holding up the sixteen or twenty foot section up to fasten it that is a worry!
Cutting the sixteen foot piece in smaller lengths and adding patch pieces that overlap the original with extra pop-rivets would* work though there would be some strength lost.
Mostly items in the shell are set and forget - worked well for mine for 40 years
Old 09-21-2011, 03:52 PM   #3
There is no AC ducting within the roof.
What year is your Airstream?
Old 09-21-2011, 07:18 PM   #4
Images: 18
Andy,
No I know there is no ducting now but thought I might put some in one day. I have a 1994 34" Excella Classic.
Old 09-21-2011, 09:41 PM   #5
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Andy,
Sadly, there is no space above the present ceiling that you could put a duct. There is only a couple of inches between the inner skin and the outer skin, interspersed with ribs which can not be removed and best not be altered.
John W. Irwin
WBCCI #9632
Airstream Central Control Panel DeltaBlues11 Electrical - Systems, Generators, Batteries & Solar 20 09-02-2014 04:24 PM
120 AC panel Board (Help) Rust Electrical - Systems, Generators, Batteries & Solar 1 08-27-2011 11:47 AM
Hybrid fuse panel pgr32e Batteries, Univolts, Converters & Inverters 1 07-14-2011 09:56 PM
Interior panel removal...floor access PA BAMBI II Repairing/Replacing Floor &/or Frame 1 01-03-2011 01:13 PM
