Old 08-18-2011, 03:56 PM   #15
Baltimore , Maryland
.032 is plenty thick. Sometimes thicker is easier to work since it does not fold over as easy, but .025 is a good working thickness for the interior..
Old 08-18-2011, 05:21 PM   #16
worldinchaos's Avatar
1959 17' Pacer
Long Beach , California
Hmmm.. I think it's finally time to invest in some air-powered shears. My aviation snips aren't going to "cut it".
Thanks!
- Peter (and Marie)
TAC CA-15
1959 Pacer 18' Renovation - Knight in Shining Armor
Our Adventure Blog - Documenting our backpacking, hiking, camping, and Airstreaming
(still updating, haven't gotten to the Airstream trips yet)
worldinchaos is offline   Reply With Quote
Old 08-18-2011, 05:51 PM   #17
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
A nibbler for curves using a rounded guide bar made out of thin plywood worked for me - except beware the working punch head will drift off true (eccentric) so its cutter handle has to swing around to always maintain evenly a 90° angle at the cutter head relative to the curve... no fun when it wavers or binds up.
Also, be selective on the true air shears by inspecting that the cutter fits snuggly in the outer brace fingers before you buy it, I had to return the first one I bought as it had too much play and made sloppy-angry looking cuts... And use a clamped guide bar for everything!!
Old 08-18-2011, 07:33 PM   #18
Scott
GoCarefully's Avatar
1971 31' Excella 500
Defiance , Missouri
not really
A bit about aluminum sheet. 2024 is a stronger alloy with a lot of copper, which makes it heat treatable and why it is used for aircraft skin, the most common. It is, however, not at all good for polishing unless it is clad. It is also not weldable. I would be surprised if it is used on the Airstream exterior skins. The alloys we polish in Aerospace are typically 5000 series and 7000 series. They have zinc which is part of what makes them polish well. 5083 polishes very well. in my former job we polished it a lot, and made body panels for Aston Martin, Morgan, and the Ford GT from it. Some aluminum alloys do NOT have to be alclad to be polishable. However, certain alloys that do not polish well in the base material, need a layer of pure aluminum (alclad) so that it polishes well and it also helps with corrosion prevention (eg 2024). 5000 series does pretty well avoiding corrosion without needing to be clad. 5052 is another common alloy. i don't think it polishes as well as 5083. 3000 series is almost pure aluminum. it polishes well but is not very strong, mostly in tensile. Old Shelby Cobras would be made from a 3000 series. Easy to form but not strong. Flexural strength or stiffness, crumple resistance, is a concern for body panels. if you need to cold form the metal into contoured shapes, 3000 series is the most ductile but again, not as strong as you might want.
GoCarefully is offline   Reply With Quote
Old 08-18-2011, 07:35 PM   #19
Scott
Defiance , Missouri
oops.. .1000 series is more like pure aluminum. soft. but 3000 is also quite soft
Old 08-22-2011, 05:29 PM   #20
Airline's Avatar
1972 29' Ambassador
grants pass , Oregon
trimming alclad
does anyone have any experience cutting the aluminum with the "Klenk K-12" shear ? I am looking for a good cheap way to trim this stuff for interior use.My tin snip and shear collection isn't "cutting-it"
Airline is offline   Reply With Quote
What type of caulking material to use? chrischarles Leaks - Weatherstrips, Gaskets, Caulks & Sealants 29 11-08-2011 10:43 AM
Type of plastic in waste tanks Flynavy Waste Systems, Tanks & Totes 18 08-07-2011 03:15 PM
Can type 3 glass bars go on a '66? deploy Windows & Screens 6 07-08-2011 01:45 PM
What type of water heater do I need? doglickfarms Water Heaters, Filters & Pumps 12 03-28-2011 10:36 AM
Exterior Aluminum type for an 1988 Excella? Rob&Julie Ribs, Skins & Rivets 0 02-14-2011 08:04 AM
