Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 06-13-2012, 06:36 PM   #1
1963tradewin's Avatar
1963 19' Globetrotter
1963 22' Flying Cloud
1963 24' Tradewind
, , Minnesota
Insulation in 1963 Airstream
I was wondering what type of insulation to use in walls? Colin Hyde told me about some, which I would like to use, but forgot!
Psalm 67:7
1963tradewin is offline   Reply With Quote
Old 06-13-2012, 07:33 PM   #2
Central , Mississippi
Here is what I did on my '63...
http://www.airforums.com/forums/f109...ml#post1018679
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 06-13-2012, 07:35 PM   #3
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I'm putting in foam where i took out the fiberglass. just cut up te 4x8 sheets. thats whats going under the trailer too.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-13-2012, 07:58 PM   #4
reinergirl's Avatar
Hollis , New Hampshire
Most people seem to be using Reflectix ( found at HD or Lowes) or Prodex which is online, sign up for notifications and half off sales are fairly frequent.
reinergirl is offline   Reply With Quote
Old 06-13-2012, 08:02 PM   #5
Originally Posted by reinergirl View Post
... or Prodex which is online, sign up for notifications and half off sales are fairly frequent.
AMEN...weekly spam...
from today...
If you need to unsubscribe emails from Insulation4less.com,
Please click this link Unsubscribe Emails
Prodex Total Insulation $179.95 for 700 sq ft Sale plus shipping discounts thru Thursday June 14(while supplies last). See details below:
Prodex 72 Inch: $174.95 per roll. One - 6 ft. x 100 ft. roll (600 sq. ft.) 1200 sq. ft. or more orders
Prodex 48 Inch: $179.95 per roll. One - 4 ft. x 175 ft. roll (700 sq. ft.) 1400 sq. ft. or more orders
Prodex Under Concrete: $179.95 per roll. One - 4 ft. x 175 ft. roll (700 sq. ft.) No minimum amount required
Prodex Fast Action: $189.95 per roll. One - 4 ft. x 175 ft. roll (700 sq. ft.) 1400 sq. ft. or more orders. Identical to Prodex 48 inch with the exception of having adhesive running 175 feet on one side of roll.
Prodex 16 Inch: $179.95 per bag. Three - 16 in. x 175 ft. rolls (700 sq. ft.) 1400 sq. ft. or more orders
Prodex 24 Inch: $179.95 per bag. Two - 2 ft. x 175 ft. rolls (700 sq. ft.) 1400 sq. ft. or more orders
Prodex Perforated: $179.95 per roll. One - 4 ft. x 175 ft. roll (700 sq. ft.) 1400 sq. ft. or more orders
Prodex Garage Door Kits: Was $119.95 now $99.95.
Prodex Under-floor & Carpet: $59.95 per roll. Buy 1 Get 1 Free!One - 4 ft. x 65 ft., 7 inch roll (262 sq. ft.)
Prodex Total is More than a Radiant barrier - It's ALSO a Reflective Insulation (R-value 15.67) AND a Vapor Barrier - All in one product!
Energy Star Qualified, ICC-ES Recognized, Member of U.S. Green Building Council - This versatile product is One solution for Heat, Cold and Water. It keeps your structure cool in summer, warm in winter and dry all year. Prodex Total works great in hot and cold climates. Unlike fiberglass insulation, Prodex R-value is unaffected by humidity. Unlike radiant barriers, Prodex has two reflective surfaces. Unlike bubble insulations, Prodex has a quality core that seals around nails and doesn't collapse. 13/64 inch (5mm closed cell polyethylene foam covered on both sides with .0012 inch (0.03mm) aluminum foil facing.
www.Insulation4Less.com
Old 07-15-2012, 09:06 PM   #6
1963 24' Tradewind
, , Minnesota
from today...
How many feet of Prodex did you buy Hihoagrv, and what width? Did you do the floor as well? Thanks for the help, as I do not want to buy more then I need.
Psalm 67:7
Old 07-16-2012, 09:52 AM   #7
I used one 4' wide roll and a small roll of reflectix from a Big Box Store. This was enough to do a double layer in the walls/ceiling. I used sheet foam under the floor. Almost every scrap was used.
