Old 09-20-2009, 10:37 AM   #1
gutsgolf's Avatar
1972 31' Sovereign
Hattiesburg , Ms
Send a message via AIM to gutsgolf Send a message via Skype™ to gutsgolf
Insulate floor or not.
we live in the south and will not be up north when it is really cold. I have belly pan off. should i insulate or not. it was a mess down there.
any recommendations will be appreciated
Richard & Marika
31' International
Land Yatch
"Silver Belle"
AS 16741
gutsgolf is offline   Reply With Quote
Old 09-20-2009, 11:05 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
In the south I think fiberglass insulation will collect more moisture from humidity than the insulation value will warrants. If you are running the AC you will reach the dew point somewhere in the thickness of the insulation. In the summer in New Jersey my parents house at the shore and over dirt, with exposed fiberglass insulation, would be dripping wet during the summer. If you have the pan off I would consider a spray on vapor barrier like undercoating, frame and floor.
2004 Excursion 4x4
Old 09-20-2009, 11:20 AM   #3
georgezink's Avatar
1977 Argosy Minuet 6.0 Metre
Cape Coral , Florida
I wouldn't use insulation under the floor. Use carpet or a click floor with padding to provide a little protection. Since heat rises, it won't be that big a deal. Insulation in the belly pan will just collect moisture and rot your plywood sub-floor.
flcracker
georgezink is offline   Reply With Quote
Old 09-20-2009, 12:33 PM   #4
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
What about using that reflective insulation stuff? Would you think that would cause a problem? We're contemplating the same things as Gutsgolf right now, and could use some direction too. Thanks.
Kay
Old 09-20-2009, 01:21 PM   #5
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
I chose not to use any insulation at all in the belly pan. It was a real stinky, wet mess down there, so I just left it out.
www.nesa.org
Air No. 6427
What should I use to insulate the floor? mbatm01 Repairing/Replacing Floor &/or Frame 22 01-10-2018 08:25 PM
New Floor Airdaddy Floor Finishes 11 07-10-2009 06:54 AM
Insulate those hot water pipes. LTD30 Fresh Water Systems 2 06-09-2006 03:23 PM
Need a new floor jlester Repairing/Replacing Floor &/or Frame 15 01-11-2005 08:04 PM
