Old 08-03-2014, 04:27 PM   #1
Mount Airy , Maryland
Installation of laminate flooring
Just removed the flooring in our 2000 Excella and now looking for instructions on installation of laminate flooring. We have purchased tongue and groove laminate to install. My first question is once the subfloor has been prepped what type of mositure barrier should be used. The video that I watch suggestes a plastic mosture barrier but I bought papper. Please let me know what you have used and why?
gwillie is offline   Reply With Quote
Old 08-03-2014, 05:24 PM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Check with the manufacturer of the laminate for their recommendation.
Old 08-03-2014, 09:47 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
We installed exactly what we have in our home. It has glued on foam backing. We put NO moisture barrier as we WANT to see moisture if it gets there.
I went to within 1/4-3/8" from the edges/sides and finished in trim quarter round. Front 10 feet we ran one direction. Next 10 another way. Last 12 returns to original direction.
Floor totally floats!!! No glue!!!
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-06-2014, 10:08 AM   #4
Hiawassee , Georgia
What to use as a backer depends upon the type of flooring. I am installing a floating snap together laminate which specifies a 1/4 inch foam backer. I am not a fan of glue down because laminate will warp if moisture develops. If you have to remove a glue down installation (regardless of the type of flooring), it is a difficult task. As a starter I sealed the subfloor with an exterior porch paint. I reinstalled the furniture and cabinets and installed flooring up to the edge. This will make it easy to repair/replace flooring should the need arise.
JumpingJoe is offline   Reply With Quote
Old 08-06-2014, 10:21 AM   #5
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
We used a T&T laminate that floats over a very thin foam underlayment sheet bought from the same store as the flooring. Been in 4 years now. Best improvement we have made to the trailer for our use.
Old 08-06-2014, 11:39 AM   #6
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
The first Excella I did was a 2000, 30'. The laminate was made by Mohawk. They recommend a thin firm foam under layment that was no more than 1/8" thick. It worked fine we used It for 2 years with no problems. Some companies have an underlayment that is glued to the laminate, I used that on a customer's Airstream, it worked fine also.
Don't use an underlayment more than 1/8", or there will be too much flex.
I've installed all of mine "east and west", as it makes the coach look wider.
Good luck!
Larry. ��
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
HELP with Laminate Flooring betsy28 Floor Finishes 17 04-22-2008 02:09 PM
Laminate flooring over old VAT tiles? jadedacres Floor Finishes 16 07-24-2007 02:31 AM
Requesting Advice on Laminate Flooring Atlantica Floor Finishes 19 07-27-2006 09:35 AM
Laminate flooring up for grabs pinkflamingoes Upholstery, Blinds, Walls & Interior Finishes 0 07-11-2006 11:38 AM
Laminate Flooring Help! Safari Tim Floor Finishes 26 03-05-2005 04:31 PM
