Old 03-11-2015, 12:54 PM   #1
1976 31' Sovereign
Oswego , Illinois
Smile Inside end caps
On forum before can not find. My front end cap is plastic from fact. not fiberglass replaced 1 time but rivets to close to edge so several cracks again. stop drilled helped little but still ugly how to repair w/out removing end cap as much drilling and mess never again. Maybe person that was at Morain view year before last will see this as he did his and exc. job.
Old 03-18-2015, 10:14 PM   #2
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
Hi, In my fridge restoration thread I detail what product to use, methylene chloride (also called Dichloromethane) and a step by step of how to repair the plastic, as well there is a link to my end cap refurbishing. I did use the same product on a very minor crack in my end cap as well but it was such a small repair I didn't document it. Hope this helps you...
http://www.airforums.com/forums/f425...om-125067.html
thesignlady is offline   Reply With Quote
Old 03-19-2015, 02:34 AM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
That plastic is 40 years old. It is ABS and has more that likely degraded badly. If it has yellowed, it has likely lost much of its ductility. If you are going to use the unit going down the bumpy US highways, it will likely crack again, in the same locations. They units move around as they go down the road and stress the interior skins. It is messy, but a thin coating of fiberglass is the easiest, least costly, way of extending the life of the unit. I have never tested whether a coat of elastomeric texture paint might work, if you can find one to stick to the ABS.
Is this the end of my end caps? unit13 Upholstery, Blinds, Walls & Interior Finishes 9 01-02-2017 10:42 AM
What are the inside end caps made of? Glue to use? ventport All Argosy Trailers 7 07-08-2012 12:21 PM
Stripping the Interior End Caps--Am I Nuts? ironfem200 General Interior Topics 2 01-29-2006 04:07 PM
What kind of interior paint 1971 Overlander/End caps dingy riverdreamer Upholstery, Blinds, Walls & Interior Finishes 5 05-24-2004 09:36 AM
Styrene end caps for the aluminium bed extrusions chasgould Upholstery, Blinds, Walls & Interior Finishes 0 05-23-2004 04:23 PM
