Old 10-07-2011, 10:48 AM   #1
Vblgrl9's Avatar
1978 31' Sovereign
Raleigh , North Carolina
Inner shell Rivet Removal
What is the best tool to remove the inner shell rivets?
Vblgrl9 is offline   Reply With Quote
Old 10-07-2011, 10:56 AM   #2
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
A sharp putty knife and a hammer!
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 10-07-2011, 11:11 AM   #3
# 30 drill bit.
When using a chisel, one slip and you may have gouged the metal or vinyl covering, depending on the year.
Old 10-07-2011, 12:45 PM   #4
Vblgrl9's Avatar
1978 31' Sovereign
Would that be for the rivets in the fiberglass for the bathroom as well?
Old 10-07-2011, 12:58 PM   #5
Every place on the interior.
Old 10-07-2011, 01:01 PM   #6
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Put some extra weights on your wheels, put too much tension on your equalizer bars, and drive down Interstate 5 in California. That should do the trick.
Just kidding.........
I go with Andy's #30 drill bit. Check to see that the "nail" that is in the center of the rivet is not protruding. If it is, use a small pin punch to drive it in a little so that the drill bit does not slip from the center of the rivet head and damage the inside surface of your trailer.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 10-07-2011, 01:09 PM   #7
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
If you take tap putty knife between the sheets to be removed, any slips are in the under sheet not the top, where it would show if you slip with the drill. Just how you look at it.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Old 10-07-2011, 03:26 PM   #8
Vblgrl9's Avatar
1978 31' Sovereign
Thanks everybody
Expansion anchors instead of elevator bolts for shell on floor replacement? timzog Repairing/Replacing Floor &/or Frame 4 12-12-2011 05:43 PM
Rivet removal question esmaytum Ribs, Skins & Rivets 2 08-07-2011 05:32 AM
1970 Shell Off Questions P&K Repairing/Replacing Floor &/or Frame 1 07-22-2011 07:22 PM
Rivet Tutorial TX_Argosy Ribs, Skins & Rivets 5 05-24-2011 04:19 PM
Shell removal confusion P&K Repairing/Replacing Floor &/or Frame 6 05-21-2011 06:32 PM
