Old 05-26-2013, 08:38 AM   #1
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
Indirect Lighting Upgrade
1999 Excella Classic - So, after looking at the lighting accents in that new Italian Land Yacht I wanted some of that indirect look. It was easy. A 50-inch strip of LED modules with peel-and-stick backing, a simple dimmer, and bingo! Fed the lead down through a small hole in the top to the existing radio unit.
Name:	12-volt LED Indirect.jpg
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 05-26-2013, 09:26 AM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Looks Great!
Lot's of amazing variations coming out in LED now.
Old 05-26-2013, 02:21 PM   #3
2011 31' Classic
Images: 8
Thanks, Lewster! We all value the advice you give us here.
Old 05-26-2013, 02:28 PM   #4
lewster's Avatar
THANKS!
Old 05-26-2013, 05:31 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Add some above and under side curtain valence...
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-27-2013, 09:47 AM   #6
2011 31' Classic
Images: 8
Nice, Channing! I like the look left and right, too!
Old 05-27-2013, 10:05 AM   #7
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
Thats great- I want to do indirect in ours as well, what kind of LED tape did you use? Did you need a separate driver or could you just hook it straight to the 12V system?
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 05-27-2013, 12:20 PM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I got the led strip and dimmer/driver off Amazon. Don't recall vendor but can
Channing
WBCCI# 30676
Old 05-27-2013, 12:25 PM   #9
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I can get the names but you may be able to find better!
If you can't find then ask and I will try to find my sources.
I used the 3500 Kelvin for "warm white". But you can go over 4000K and it looks like close encounters of the fourth kind.
Channing
WBCCI# 30676
Old 05-27-2013, 02:32 PM   #10
Globie64's Avatar
Images: 18
Thanks- I've been wanting to replace the existing spot lamp bulbs with LED, but I'd use 2700- 3000k to be more like incandescent. I'll look on Amazon-
Old 05-28-2013, 06:41 AM   #11
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Globie,
With the 3500 and dimmer I can adjust brightness and somewhat color too.
The 3500 look like new incandescent. But then I am a bit color blind.
Channing
WBCCI# 30676
Old 05-28-2013, 07:28 AM   #12
2011 31' Classic
Images: 8
I got my strip and dimmer from a small company in Illinois. $29.00 includes shipping. I hooked directly to the 12v power for the radio in the cabinet. PM me for getting one and I'll look up the data.
Old 05-28-2013, 05:05 PM   #13
Globie64's Avatar
Images: 18
Thanks for the contacts- I'm stoked to try some of the tape in other locations in the trailer and a dimmer (reasonably priced) is a huge plus.
Old 05-31-2013, 10:50 AM   #14
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
I've got a couple places where we removed drapes to put in miniblinds but left the valence where I'm gonna put LED strips. I haven't made up my mind yet between the select-able color strips or just a warm white.
In Arizona, glue doesn't work. Anything glued falls off when it gets hot.... and I'm talking Real Freakin' hot. I wonder what else would work...??
