My toilet paper keeps unrolling all over the floor during travel.
It’s a basic stock ‘64 recessed holder.
How do you keep it from unrolling??
On ships we had a rolled stainless steel serrated “cover” that prevented this.
Anyone know where I can find one?
Safari64
Mine never does this, have you had your running gear balanced? How's the axle? You know, I've seen plastic covers in pet stores... designed to keep your kitty from amusing herself when you're not there, but it would probably work for T.P. traveling too.
We take an empty plastic water bottle 1-liter size, cut off the ends and split it lengthwise to slip over the TP roll while underway. The 2-liter size works well for paper towels...
Shari
we used to do the rubber band too with the sob, doesn't move on the AS. Rubberband over the roll holder insert than over the paper for travel then pulled off to the side without having to remove the insert for use.
Remove the toilet paper from the roller, squeeze the sides together until the center cardboard tube looks like this (), then put it back on the roller. Now it should not unravel as you travel.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Charter Associate Member FCU
Airstream Life "Old Aluminum Adventures"
Of course, if you squeeze too hard, you will wind up with lots of short lengths of TP...
Something I have used, is an oversized paper clip, through several layers.
Terry Important safety tip: Battery acid + baking soda= volcano...
AIR#2611
I guess that by '68 things got really hi-tech. In 1968 Frank Boorman, Apollo 8 commander, refused to orbit the moon unless they fixed this TP problem. At launch the vibration would make the tp unravel so once they hit weightlessness the unraveled paper floating through the orbiter became quite bothersome. NASA scientists went to work on a new plan to create an in-flight tp containment center, also known as the IFTPCC. Airsteam soon adopted this new technology in all new '68 trailers; they called it the WBTPCCI.
Here is a few pictures of the TP holder in park and launch sequence.
Our Bambi did this all the time. My fix was not as neat as what has been posted.....I just took the roll out and set it on the floor on it's side.
Haven't had the issue with the Safari to have to worry about doing it or any of the other fixes.....
Too funny!
__________________ Michelle & Leon
WBCCI # 7032 Region 1, New England Unit
Looking for a WBCCI Unit filled with fun loving folks to camp and travel with in the New England area? Well, you've just found it:
Love the humor in this thread uberlanders I was cryin from laughin so hard!!
Paula--hope my post (#6) wasn't offensive, surely didn't mean it to be. I thought you might have been funnin on that one so I was laughin with not at your response--important clarification. Couldn't give ya more pos karma cause it said I gave ya too much already...Guess that's what I get for reading the hanger falling off the closet/running gear jokes on another thread...
Best to all.
__________________ Steph in MI Air# 6996- I Hockeytown USA!!
