Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 11-03-2015, 11:04 AM   #21
1973 29' Ambassador
Vancouver , Washington
Hurray!
Hurray! You're done. Big pat on the back. What an incredibly job. Very retro.
Amybeth is offline   Reply With Quote
Old 11-03-2015, 11:07 AM   #22
1998 28' Excella
Little Rock , Arkansas
awesome!! enjoy! Great job!
Gillpine is offline   Reply With Quote
Old 11-03-2015, 11:16 AM   #23
1964 26' Overlander
Orange , Texas
64 look
Thank you for the wonderful post!
I have a '64 overlander and your pics will be invaluable as we restore. We want it as original as possible.
After I get the b. water tank fixed I plan on replacing the toilet, etc. Great job!
Doctari
doctari is offline   Reply With Quote
Old 11-03-2015, 11:32 AM   #24
NoNameinNM's Avatar
2016 28' International
Albuquerque , New Mexico
Wow-- you have done an amazing job and I am jealous! That is precisely what I dreamed of when we were considering whether to purchase and restore a vintage unit or buy new. Your Airstream will undoubtedly be an inspiration to many!
NoNameinNM is offline   Reply With Quote
Old 11-03-2015, 11:50 AM   #25
1967 26' Overlander
Spartanburg , South Carolina
Quesstion about refrigerator
Originally Posted by robwok View Post
A tiny bit. I removed the inside plastic in the door, and repaired it from the back side. However, I did touch up a little bit on the front side to smooth out some plastic repair I did. Mine was bright white, so I was able to use a bright white plastic paint without a problem.
My '67 Overlander has never been restored but has been in frequent use as a family camper for 48 years. The original refer has a 3/8th inch thick door gasket with a magnetic strip instead of the more modern 3/4 inch. I literally called all over the world trying to find a replacement including Dometic in Sweeden but no dice. I found a 3/8th gasket for a larger door in the flea market at DuQuoin International rally and was able to cut it down to fit, but it is not perfect. In a unit as old as yours, you must have had a need for a new door gasket. What did you do? I ask because I plan to pass the trailer on to my son and sooner or later it will need a new gasket again.
Jacob D is offline   Reply With Quote
Old 11-03-2015, 11:50 AM   #26
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
NoNameinNM, sorry you pulled the trigger so quick. It's for sale.
doctari: I didn't have to pull the shell on mine because it was in great condition and had almost no mice issues - a little in the belly pan, but just insulation which I replaced. If you search for my handle - robwok, I documented everything I did replace - axles, tires, 7 way, hot water tank, all the holding and supply tanks, toilet, dump valves, etc. I plan on taking a video as there are several things that don't show in the pictures that well. For example, since I had the belly pan open, I added wires and LED lights at the stairwell, underneath, and in the bumper trunk and rear compartment, so if you go to hook up your dump stuff at night, you flip a switch and everything is extremely well lit and easy to see.
robwok is offline   Reply With Quote
Old 11-03-2015, 11:54 AM   #27
59' Globester
twolanehwy's Avatar
1959 18' "Footer"
1957 26' Overlander
Three Rivers , California
Coolo, like that toilet deally.
twolanehwy is offline   Reply With Quote
Old 11-03-2015, 11:54 AM   #28
Royce's Avatar
1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
Truly beautiful workmanship. An inspiration to all.
Royce (K0RKK) 146.460 simplex
Web page https://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
Royce is offline   Reply With Quote
Old 11-03-2015, 12:29 PM   #29
AudioMike's Avatar
1966 22' Safari
Englewood , Colorado
I know it's alot of work, but you should be very proud of staying true to the era. Awesome job!
Audiomike
1966 Safari
2001 Silverado 2500HD
AudioMike is offline   Reply With Quote
Old 11-03-2015, 12:35 PM   #30
Well done
Beautiful, original and functional. Well done, cdfriend
cdfriend is offline   Reply With Quote
Old 11-03-2015, 12:58 PM   #31
NoNameinNM's Avatar
Oh, if you only knew... it was at least a dozen years before we actually "pulled the trigger" and even then it was a dream of several decades. We left the Vintage Trailer Academy in May of last year having realized that we would pass on restoring a vintage unit and instead buy a new or used late-model Airstream instead. And then we waited almost a year before actually ordering ours!
Still, if I had the cash laying around, I'd be on my way right this minute! It's absolutely gorgeous and I'm sure the next owner(s) will treasure it.
Old 11-03-2015, 02:38 PM   #32
2000 30' Excella
2014 30' Classic
Princeton , Iowa
Wonderful pictures. What a great job. I would like to know about how many hours and dollars you have in it?
larryglarson is offline   Reply With Quote
Old 11-03-2015, 02:47 PM   #33
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Ignoring the purchase price, I have about $13,500k into it. I recently put all my receipts and purchases into a spreadsheet, so I have an itemized list of everything that went into it. Hours? I didn't keep track. There were so many hours of research trying to figure out things, and then the hours on my back working in the belly pan, and hours wrapping my fingers after cuts from sharp aluminum, and hours at the masseuse trying to get rid of locked up muscles, and hours watching weather forecasts... I would say maybe 1,000 hours? I'm a bit of a perfectionist. I did extra things like spray paint the axles since I don't trust powdercoating, and painting all the bolts after they were on, just because it was so hard to get the old rusted ones off, and adding steel in spots underneath and in hidden areas that I thought were weak. But if I think of whole days, 1,000 is within reason. I'm not counting my wife's time in the upholstery and curtains, but I think she probably had 100-200.
Old 11-03-2015, 02:48 PM   #34
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
And you haven't seen the finished outside yet. It's almost ready for pics.
Old 11-03-2015, 02:56 PM   #35
Society Hill , South Carolina
Very nice job!
Martin1214 is offline   Reply With Quote
Old 11-03-2015, 04:14 PM   #36
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
Awesome! Love your commitment to restoring it back to original as much as possible. Your completion (if they ever are really complete) is an inspiration to all of the rest of us that are in the middle of a total restoration.
Gregsch is offline   Reply With Quote
Old 11-03-2015, 04:53 PM   #37
Stanwood , Washington
Wow.......way cool! Great job!
dfschultz is offline   Reply With Quote
Old 11-03-2015, 05:20 PM   #38
2000 28' Excella
Godfrey , Illinois
Beautiful, you're hired!
Relaytest is offline   Reply With Quote
Old 11-03-2015, 05:24 PM   #39
beaumont , Texas
resto
I think you did a spectacular job on your trailer. A lot of us appreciate the original look and how hard it is to accomplish. I may have something you would like for this.. an original fire extinguisher.. cam out of a late 60's.. just a thought. looks great Richard.
Dixie722 is offline   Reply With Quote
Old 11-03-2015, 06:13 PM   #40
Alumaholic's Avatar
2019 27' Flying Cloud
Images: 36
It's a real beauty! Thanks for sharing !
Ken L
2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Goucho couch,original am/fm 8 track & lots of wood & aluminum from interior remodel gquailhunter Airstream Classifieds 0 09-19-2015 04:25 PM
Our '74 Tradewind remodel (almost done) chromechaser 1970-79 Tradewind 11 09-09-2012 01:03 AM
Want to remove original interior paint finish on 64' what is best way? Olivebranch Upholstery, Blinds, Walls & Interior Finishes 6 02-08-2012 11:52 PM
Do you see what I see? Foiled Again Airstreams on eBay 3 12-28-2011 04:51 PM
Bath remodel finally done... safari25-05 General Interior Topics 4 08-11-2010 10:19 PM
