Old 07-29-2008, 03:33 AM   #15
Baltimore , Maryland
I just want gold anodized aluminum.
Old 07-29-2008, 08:08 AM   #16
mandolindave's Avatar
My rig almost fits my needs.
But what about an air conditioner that works on a 20 amp circuit, and a 2000 watt jenny. My house window AC works on a 20 amp service.
mandolindave is offline   Reply With Quote
Old 07-29-2008, 09:12 AM   #17
cameront120's Avatar
1972 25' Tradewind
I want to see a non-organic sub-floor material (read permanent) used for all models! No more plywood to deteriorate!
North Vancouver, BC
Old 07-29-2008, 08:39 PM   #18
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
All of the specifics that have been mentioned are pretty neat - but I also think that airstream designers must overcome some of their chronic challenges by:
  • revisiting what seem to be some lost historic principles in Airstream design and construction:
    • innovation
    • toughness
    • longevity
    • continuous improvement.
  • seeking out, listening to, and responding to customer feedback:
    • toss out the 48" bed
    • find a quiet stove fan
    • find a quiet fridge fan
    • address the filiform corrosion issue
    • there are others ....
  • remembering that key design principle:
    • form follows function
  • demonstrating a commitment to quality control:
    • resurrect the lifetime warranty
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Old 07-30-2008, 05:19 AM   #19
Be Not Afraid JMJ + AMDG
Roamin Cat's Avatar
2008 25' Safari
Quiet Green , Connecticut
Rivet Amen!
    • innovation
    • toughness
    • longevity
Jay
From your keyboard to their eyes, I hope!
Cats
AIRSTREAM Life
"Color delights my spirit"
avatar artist
Roamin Cat is offline   Reply With Quote
Old 07-30-2008, 08:50 AM   #20
Roamin Cat's Avatar
2008 25' Safari
Wink I'm not so original after all
Originally Posted by 2airishuman View Post
a couple of MAJOR things noted in this thread (posts #69 & 120), IF put in place, would cause a positive cascade of things...
http://www.airforums.com/forums/f232...ngs-29964.html
this thread has other folks ideas, a picture of that double door 34...
http://www.airforums.com/forums/f232...nts-18053.html
really they need to focus of genuine innovations, better build results and safety too,
http://www.airforums.com/forums/f353...afe-39545.html
instead of gimmicks like flipping floor plans, fabrics and cheap vinyl patterns...
but u asked right?
and once one SEES how the interiors go together, floor plan changes are relatively easy....
but the basic structure, shell materials, towing qualities and historic durability are the 4 corners that need support.
cheers
2air'
Thanks 2air',
I've read through the threads you posted, and see the same basic issues mentioned over and over again. I pray the Mothership catches on the the basic 4 corners you and so many have mentioned, as this is obviously the most important focus!
Nice to see Airstream working with Gene (thank you!!!) and the other top dealers; I see some of the suggested improvements incorporated into my '08
Cats
AIRSTREAM Life
avatar artist
Old 07-30-2008, 08:57 AM   #21
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
I'll Second That!
This has been a major thorn in the side of Airstream for almost forever. What gives? You spend upwards of $100k for many models and the floor rots. Get a clue Airstream! This is an issue that certainly should be high on any product improvement list.
Lucius
Lucius and Danielle
1992 29' Excella Classic
1996 GMC Suburban C2500 7.4L
2005 Chevrolet Suburban K2500 8.1L
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 07-30-2008, 10:09 AM   #22
ianrjam's Avatar
1978 25' Tradewind
London , England
Space
The space inside the Airstream shell is not just large, it is beautiful. Across the world designers of trailers think it is clever to occupy every available corner with lockers and other various cabinets which add weight. But worse, it obscures the Airstream shape, removes the feeling of space and gives an almost claustrophobic feel. I took the overhead lockers out and other owners think mine is bigger! I sometimes have to point out their's is bigger. There is loads of storage space around at lower levels.
OK. If I was an Airstream designer, I would make the high level storage lockers an optional extra. If people viewed the new model without them, would they order them? To remove them from a new Airstream, it is hard to fix the scars. And Airstream might sell more units!
ianrjam is offline   Reply With Quote
Old 07-30-2008, 12:12 PM   #23
bobfowler's Avatar
1972 Argosy 20
Middletown , New Jersey
Images: 14
Not to mention the addition of all that weight up towards the roof moves the center of gravity higher. Having said that, we spent the weekend rebuilding the cabinet above our sink.
As I mentioned in this post, we lost that cabinet to the wonderful condition of Interstate 78 back on June 22nd. Fortunately, the stove hood and sink light survived the crash intact, they pretty much pivoted down and just pulled some wires from their connectors. We were able to reuse the cabinet front, but needed to make a new end panel (trailer front) and bottom. On the positive side, all of the aluminum parts were fine and we made the new wood parts from 1/4 birch plywood which is a LOT stronger and about the same weight as the original materials. Also, the underside of the cabinet is now a bright, gloss white which does wonders for the lighting in the kitchen area.
The next project will be to make a new lower cabinet/countertop to replace the sagging mess that currently resides in that location. Oh yes, and a new cover for the fridge vent...
Bob Fowler
Some people are like Slinkies. They're really good for nothing, but they still bring a smile to your face when you push them down a flight of stairs.
TAC - NJ-007
bobfowler is offline   Reply With Quote
Old 07-30-2008, 01:06 PM   #24
qdp
2004 25' International CCD
Pacific Palisades , California
It's all It is more about doing, not talking, as Wally did. My point is, go beyond improving, constantly question, learn and adapt. Out-of-the-box thinking brought us A/S, why stop now? While art is in the beholder's eye, functionality is how it applies and works.
See: http://www.airforums.com/forums/f160...tml#post596888
Great ideas you guys, love the commitment!
Quentin
qdp is offline   Reply With Quote
Old 08-07-2008, 10:41 AM   #25
Central , Mississippi
I'd start with this 29'-31' floorplan and tweek the interior finishes to suit. The layout is designed for a grumpy ole fulltimer wanna be...me!
(Kinda lookin' for a donor shell to give it a shot with)
Name:	rear bed floorplan v2.JPG
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 08-07-2008, 12:28 PM   #26
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
I'll have to play around with a "floor model" 10K BTU air conditioning unit I bought a few years ago, when our main house A/C unit went out. I know the SEER rating is about 9 or so, Coleman unit is probably 5, if that. Thinking of putting it where the fridge is now, so I could use the vent as the hot air exaust and going with a small electric apartment fridge, instead of the large one that is there now. Maybe even build a shelf for the mini fridge to set on, above the A/C unit.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 08-07-2008, 01:54 PM   #27
1967 22' Safari
South East Idaho , South East Idaho
Originally Posted by uwe View Post
Paula, no need for 2 water heaters - the system as you describe it already exists. Twin Temp jr. by precision temp.
We have been installing these in client projects, with fantastic results. Your imagination is the limit, just about any surface can be a radiant heat surface, especially in an all metal trailer. The heat exchangers ( radiators as you call them) have computer muffin type fans behind them, and resemble an automotive heater core. The fans require very very little from the batteries or electrical system, and are ultra quiet. The heater doubles as an instant water heater, and is about the size of a 6gal water heater. It does not require a cutout in the skin, but rhather vents through the floor. Placement therefore is very flexible, like it could easily be underneath a center queen bed, for example. I think that the units are worth every penny, even thought hey cost many many pennies....
I am gutting my 67 Safari. And would like one of these heating units. Have toyed with looping a line around the perimiter of the coach tied into the water heater. and a solinoid valve to Isolate the loop in warm months ect. Of course the loop would have to equal the presure of the water heater.
Grad67 is offline   Reply With Quote
Old 08-07-2008, 02:31 PM   #28
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up I would.....
STUDY A LITTLE HISTORY
but Im the Husband, so we went to Cleveland. 😘
RLC
Its a crooked piece of time that we live in.
John Prine
How Many Airstreams Janets Husband Community Polls 6 10-25-2006 01:49 PM
How many airstreams LI Pets Off Topic Forum 11 10-18-2006 05:59 AM
Designing a new instrument panel 74Argosy24MH Mechanics Corner - Engines, Transmission & More... 21 09-05-2003 08:00 PM
Used Airstreams.com ipso_facto Link Archive 1 03-22-2003 08:50 AM
Custom Designing Cat Cabinets, Counter Tops & Furnishings 0 07-22-2002 02:09 AM
