Old 08-21-2008, 08:34 AM   #1
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
I need help in the bedroom!
Thought that would get your attention.
We replaced the factory queen bed in our Safari Bunk with a custom residential pillow top innerspring queen mattress. It is much heavier than the foam mattress that came from the factory and the two struts that were installed to aid in lifting the bed aren't nearly strong enough. They will barely hold the bed up to access the storage underneath. Often the bed will fall if I don't hold it up while accessing the storage...and this is where we keep the liquor! We also keep the grill under the bed. My wife can't lift the bed and I have to do it for her. Needless to say this isn't good for my already bad back.
I asked the Airstream dealer nearby to give me a quote on larger struts or a power bed lift while they were doing some warranty work on the A/C. Instead they just moved the base of the struts a couple of inches forward and charged me $100! Needless to say that was my first and last time using them for work on my Airstream.
Anyway, I thought I would either add a third strut or replace one or both of the existing struts with larger struts to make lifting the bed easier. Does anybody have a suggestion as to what size to add to the existing struts or what size to move up to if I enlarge one or both of them? Also, can I get them at the auto parts store?
Family of Disney Fanatics
WBCCI# 4821
Old 08-21-2008, 08:46 AM   #2
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Minnie's Mate,
I can't speak to the strut size, but have you considered storing the liquor somewhere where it is easier to get at? then you won't have to lift the bed.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 08-21-2008, 08:59 AM   #3
2006 30' Safari
Orlando , Florida
I have children aboard.
Also, the wife has confiscated all the other storage spaces large enough for my liquor collection.
I don't want it too easy to get to, but I still want to be able to get to it myself. As it is now, if I'm not going in after the grill, I usually just say it's too much trouble to get to the tequila or rum, etc. to make a cocktail to go with dinner.
WBCCI# 4821
Old 08-21-2008, 09:00 AM   #4
2006 30' Safari
Orlando , Florida
Thanks for the 411.
WBCCI# 4821
Old 08-21-2008, 02:15 PM   #5
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
to bad you could put an air device on it. Kind of like an Airshock. or even an electric arm might be cool. push a button and the bed goes up like the stair case on the Munsters.
mustang is offline   Reply With Quote
Old 08-21-2008, 02:24 PM   #6
2006 30' Safari
Orlando , Florida
That's what I had in mind when I asked for a quote from the nearby Airstream dealer. He also sells all kinds of luxury class A's and figured he could install a bed lift like some of them have. Instead of giving me a quote for one of those or even a quote for stronger struts, I was presented a bill for just over $100 to move the base bracket about 2"; a charge that I did not pre-approve and the service write up clearly spelled out what I had requested. I was not amused nor was I a "happy camper". Jackson Center is aware of my dissatisfaction since they were the ones that suggested that I use this dealer.
WBCCI# 4821
Old 08-21-2008, 02:36 PM   #7
2002 19' Bambi
Lafayette , California
You can buy gas struts/springs at an auto parts store, but they might not have the appropriate mounting brackets. A Google search on "gas springs" might provide more possibilities.
Tim A. is offline   Reply With Quote
Old 08-21-2008, 02:42 PM   #8
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Hummmm, note to self, MM keeps the liquor UNDER his bed...... Must keep him sober long enough to access booze THEN let him pass out.....
The only advice - and I would guess it's not what you are looking for, is a block and pulley system. Find a rib section directly over the bed edge that is lifted and place a polished hook ar something from a marine supply that looks real nice. Have the two blocks and line tucked in under the mattress and when needed place the one block in the hook and pull the line. Every pass through the blocks reduces the weight by half.
There you go, and it will save my back in the future too.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 08-21-2008, 03:09 PM   #9
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
even a hatch back style strut off a Mustang or Camaro. I still like the automatic version better maybe the mechanism from a minnie Van side door
Old 08-21-2008, 03:11 PM   #10
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
The Block and pulley over the bed hahaha dont put a basket on it when not in use ahahaha
Old 08-21-2008, 03:14 PM   #11
2006 30' Safari
Orlando , Florida
Mike, you are welcome at the "Changes in Latitudes" bar and lounge anytime my friend. I'm not a big drinker, but I do like an occasional cocktail and enjoy sharing one with others. I usually try to keep a small variety to be able to offer something to anyone.
Note: not responsible for overindulgence, please drink responsibly.
Oh, yeah, you will be at the "End of Summer Rally Thank". Note to self...install a lock and hasp on the bed.
WBCCI# 4821
Old 08-21-2008, 03:17 PM   #12
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
I thnk you are talking to me and I am glad you appreciate the humor my freind. Check out clancy's tree stand.
Old 08-21-2008, 03:18 PM   #13
2006 30' Safari
Orlando , Florida
If I got real fancy, I could go to the Ford dealer and order a rear lift gate mechanism like my wife's Expedition has. Remote power rear door lift. It has a power hydraulic strut system. But, if it's priced like the power rear sliding window the thieves broke out on my F-250 a few months ago, I can't afford it. The rear window was over $1,200! and of course, only Ford carries it. Glad I have comprehensive insurance!
WBCCI# 4821
Old 08-21-2008, 03:20 PM   #14
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
what about a bone yard. or even a spring set up like on a garage door at the hinged end. My mind really starts turning when mechanics come sinto play.
original t.v. in bedroom jagcb750 General Motorhome Topics 5 07-02-2008 02:39 PM
Bedroom Conversion desmits General Interior Topics 9 01-01-2008 07:07 AM
Bedroom modification geodrake Cabinets, Counter Tops & Furnishings 0 10-15-2007 06:46 PM
Back Bedroom Credenza ptbasmith Cabinets, Counter Tops & Furnishings 1 07-18-2006 12:09 PM
AS bedroom theme (OT) sharmstr General Interior Topics 6 01-05-2006 01:58 PM
