08-21-2008, 04:10 PM
#21
2006 30' Classic S/O
Mohrsville
, Pennsylvania
Originally Posted by mustang
I got 200 but I didnt get the 4rth rivit how many does it take.(off Topic)
More off topic, fourth rivet must be somewhere between 200 and 300 as I have four rivets, but am not yet a vernerable "rivet master"
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
08-21-2008, 04:15 PM
#22
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
Oops, sorry, Rivet Master is 5 rivets, 500 posts.
I like the low rider hydraulic seismic bed idea.
Vaughan
08-21-2008, 06:48 PM
#23
Central
, Mississippi
If you can find a really old 8' sat dish they used a long travel linear actuator that usually runs on 24 volts. The ones I messed with would run on 12 at a much lower speed. It seems they had about 20" of travel, that would give plenty of stroke (um, poor choice of words... ) to assist lifting the bed.
The down side is Mr. Jose Quervo could be trapped in the event of an electrical failure unless you designed a quick release on one end of the strut .
08-21-2008, 07:29 PM
#24
Tom, the Uber Disney Fan
2006 30' Safari
Orlando
FYI, the bed uses a piano hinge, I think.
Hydraulics in the bedroom...scary.
Family of Disney Fanatics
WBCCI# 4821
https://streaminacrossamerica.com/
08-21-2008, 07:50 PM
#25
2011 34' Classic
Westchester Cty.NY
, / Miami FL
maybe "thing" from The Adams Family is available?
i'm starting to think of Murphy Bed humor with all these suggestions!
Ricky
08-21-2008, 07:58 PM
#26
2006 30' Safari
Orlando
That's what I was thinking with garage door opener springs. I could just imaging hitting an expansion joint on the interstate and sending the mattress through the fantastic fan in the bedroom!
These pulley and block and tackle suggestions and I'm thinking about the bedroom scene in "9 to 5" with Jane Fonda and the garage door remote.
WBCCI# 4821
08-21-2008, 08:03 PM
#27
1999 27' Safari
Kent
, Ohio
Originally Posted by vswingfield
Dang, you’re right mustang! Following that, how about a 12 volt winch attached the same way? No remote, though.
Off Topic, it’s 500 for the 4th (Rivet Master status) rivet. While off topic, love the photo on your personal info. And, what Mustang is it that you enjoy drag racing?
(off topic) It is a 90 fox body Ultra tech chassis Schorling raceing engine.
alot of fun but getting expensive. thought about selling her. To much fun though
08-22-2008, 02:36 PM
#28
1973 Argosy 26
Norristown
, Pennsylvania
Originally Posted by Minnie's Mate
If I got real fancy, I could go to the Ford dealer and order a rear lift gate mechanism like my wife's Expedition has. Remote power rear door lift. It has a power hydraulic strut system. But, if it's priced like the power rear sliding window the thieves broke out on my F-250 a few months ago, I can't afford it. The rear window was over $1,200! and of course, only Ford carries it. Glad I have comprehensive insurance!
Hi Minnie's Mate; Gas operated assist cylinders [Gas Spring] are weight rated for particular applications. Some that are made for Marine Industry go up to 26" in length and 150 Lbs lift. Those are also very cheap at about $15.00 each plus end fitting at about $3.00. If you need more lift you can double them providing you now a bit about geometry. The spring closest to the hinge will have to be offset to accommodate the equal travel distance. If you need more help PM me. Thanks "Boatdoc"
08-23-2008, 10:01 PM
#29
2006 30' Safari
Orlando
I took one of the struts off today and it was rated at 90 lbs. I called Camping World today and talked to their parts manager. They sell up to 120 lbs. lift. It's a good hour to the nearest Camping World so I went to the Autozone nearest me. I got a strut the same length, but it didn't have the rating on it or the container. The clerk looked it up in their system but couldn't find the rating in the computer. The shaft was nearly twice the diameter so I bought two and figured I could replace both existing struts and if that was too much I could use one existing and one larger one. However, I installed both in place of the two that were original.
The mattress was so heavy that even with two 90 lbs. struts, the bed wouldn't stay in the raised position with the originals. While the new ones aren't a two finger lifting operation, the bed is much easier to lift and will stay in the raised position on its own.
Not sure why the manufacturer that Autozone uses doesn't include the lift rating, but they didn't. The Lift Master that was original had the lift rating on the side.
WBCCI# 4821
08-23-2008, 10:44 PM
#30
2008 27' International CCD FB
Mill Valley
How's the bed?
Is it a lot more comfortable than the foam matress?
We're looking at replacing ours.
08-23-2008, 11:15 PM
#31
2006 30' Safari
Orlando
My wife ordered the bed through Velo. It is a custom sized, with angled corners, inner spring, extra firm mattress with pillow top cover. It is really comfortable. It was expensive but it is as comfortable as any you will get for your home. In fact, it is not an RV mattress, but a residential model that was custom made to fit the bedroom. My wife says I snore less when we camp than when I sleep in our new Simmons pillow top extra firm mattress at home.
WBCCI# 4821
08-24-2008, 12:30 AM
#32
2011 34' Classic
Westchester Cty.NY
, / Miami FL
nice to see that you can get it up without help now.
ratings on parts, now that would be nice!
Ricky
08-24-2008, 12:35 AM
#33
2006 30' Safari
Orlando
Yes, my wife will be happy now...
...she couldn't get to the liquor without my help before!
WBCCI# 4821
