Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 12-02-2014, 02:04 PM   #21
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Holly schmolly that looks like its silver plated. Very nice.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 12-02-2014, 02:48 PM   #22
millertimeUS's Avatar
1976 25' Tradewind
Great polish job and very cool photo!
76 'Airstream Tradewind
Matt
millertimeUS is offline   Reply With Quote
Old 12-03-2014, 07:25 AM   #23
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
So, hows the floor replacement going? Big gap in your thread. below is my thread on my 71 GT full Monte
Old 12-03-2014, 09:20 AM   #24
Bullit's Avatar
1971 18' Caravel
Nokesville , Virginia
Aerowood,
Good to see you have returned safe. I have a ton of questions for you. I read a lot of your threads and have been truly inspired by the "right way" you have done your AS. I am in this for a very long haul and hope to do at least a fraction of the good work you have done. Full Monty over the course of the next few years if necessary
The Caravelle is in the Polished Turd phase of restoration and modernizing; polished and shiny outside gutted, bare, rotting and rusted on the inside. I am going to do as much as I can with the shell in place (polish waterproof clean replace and refinish exterior accessories) and then pull it off and replace the frame, tanks, axles and floor. Then work on the interior. There are so many logistics in this process. So many must does before moving on.
I will probably build some gantries in the next few weeks and remove the AC and roof vent. I wanted your advice on the windows and eventual buck riveting. Did you pull the entire window frames? As in drill the rivets and then reseal and replace etc? Also wanted advice on buck riveting equipment and a good tutorial on the actual process.
Bullit is offline   Reply With Quote
Old 12-03-2014, 11:53 AM   #25
CHIEF THINGAMAJIG FIXER
1964 26' Overlander
bugtussel , South Carolina
buck rivits
. Good starting point if you have never buck rivited. Thanks youtube university.
Bugtussel is offline   Reply With Quote
Old 12-04-2014, 04:37 PM   #26
Aerowood's Avatar
Arvada , Colorado
Originally Posted by Bullit View Post
Aerowood,
Yes
Old 12-04-2014, 05:51 PM   #27
Bullit's Avatar
1971 18' Caravel
Thank you, I reread your thread and found the buck rivet info in #58.
Removing windows and skins is very committing.
Old 12-04-2014, 07:29 PM   #28
Aerowood's Avatar
Arvada , Colorado
Yup
Old 05-17-2015, 05:52 PM   #29
Bullit's Avatar
1971 18' Caravel
After a long delay I got back to work today... A little. Drilled more rivets and and removed the vent fan and separated the A/C unit. Can't figure out how to get the A/C down but I need to build a gantry anyway. That's all for now
Old 05-18-2015, 05:28 PM   #30
Bullit's Avatar
1971 18' Caravel
A/C is off! It wasn't pretty but it's done. No damage to the AS, the A/C ( not that it mattered) or me.
Name:   ImageUploadedByAirstream Forums1431991654.114407.jpg
Name:   ImageUploadedByAirstream Forums1431991672.828093.jpg
Old 07-04-2015, 01:43 PM   #31
Bullit's Avatar
1971 18' Caravel
Still plotting along, first Gantry is up with another to follow. Will need to work more on cleaning the area around the former A/C. Sorta feels pretty good to get started on the next big thing. Click image for larger version
Name:	ImageUploadedByAirstream Forums1436038979.328000.jpg
Slow going but good times ahead....
Old 10-24-2015, 03:57 PM   #32
Bullit's Avatar
1971 18' Caravel
Back to it. Gantries are in place and have begun to brace the interior for lift off. Click image for larger version
Name:	ImageUploadedByAirstream Forums1445723423.099077.jpg
Also took off the 4 corner banana wraps. Belly pan must be full as wellClick image for larger version
Name:	ImageUploadedByAirstream Forums1445723528.539630.jpg
Front street side
Name:	ImageUploadedByAirstream Forums1445723618.213452.jpg
ID:	250960rear curb side
Name:	ImageUploadedByAirstream Forums1445723655.467487.jpg
ID:	250961front curb side. I noticed the curb side lower and mid panels are double hung. The bottom edge of both lower panels can be seen in the last photo.
Anyway body should pop in the next two weeks.
Old 10-27-2015, 01:00 PM   #33
Bullit's Avatar
1971 18' Caravel
I have seen the C channel, and it is Grand!!!
Though I have read it is not necessary I put in some bracing in today. Should be really close to lift off.
Old 10-27-2015, 01:08 PM   #34
Bullit's Avatar
1971 18' Caravel
Forgot the picsClick image for larger version
Name:	ImageUploadedByAirstream Forums1445972891.450857.jpg
Old 10-31-2015, 05:37 PM   #35
Bullit's Avatar
1971 18' Caravel
Popped. Click image for larger version
Name:	ImageUploadedByAirstream Forums1446334544.680892.jpg
ID:	251446Click image for larger version
Name:	ImageUploadedByAirstream Forums1446334572.480874.jpg
Body us all strapped down. Now back to the mouse works and insulation. Should be another long day tomorrow
Old 10-31-2015, 07:21 PM   #36
mapleton , Utah
Houston, we have lift off! This is where the fun really starts. Plan now for your final design concept and place your grey, black and fresh water tanks while you repair the frame and floor. It will save you a whole lot of headaches later. BTW that polish is looking AWESOME!!
tim
rumrunner is offline   Reply With Quote
Old 11-01-2015, 04:03 PM   #37
Bullit's Avatar
1971 18' Caravel
Well, I thought removing the interior was rough... Getting the C channel and "A single" floor section off was as bad. That being said, the C Chanel is in pretty good shape which is a good thing 'cause making templates from my floor ain't happnin. C channel has been mounted on 1/4 plywood for later use on templates.
The floor is a mess
Name:	ImageUploadedByAirstream Forums1446418543.616730.jpg
The back has the expected rot...
Name:	ImageUploadedByAirstream Forums1446418587.386109.jpg
The front was also pretty rotted
Name:	ImageUploadedByAirstream Forums1446418669.558919.jpg
Got the front off.
Lastly, what does everyone else do with all the cool AS Souvenirs you get from doing the full monte?
Name:	ImageUploadedByAirstream Forums1446418793.948004.jpg
Good times, Good times.
Thanks again to everyone who has gone this way before. I depend on the forum to remain motivated!
Old 11-01-2015, 04:36 PM   #38
Central , Mississippi
Good looking progress.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 11-03-2015, 06:35 AM   #39
Bullit's Avatar
1971 18' Caravel
The progress continues
Name:	ImageUploadedByAirstream Forums1446556620.498798.jpg
Special thanks goes out to whoever came up with this methods for hole sawing around the elevator bolts. Click image for larger version
Name:	ImageUploadedByAirstream Forums1446556718.756452.jpg
If there is any doubt about Colin Hyde's explanation of why water gets into the back of 70s trailers, here it is (as I understood it)
Name:	ImageUploadedByAirstream Forums1446557027.082864.jpg
That 4 inch aluminium plate to the left of the bumper literally collects and directs water under the body
Name:	ImageUploadedByAirstream Forums1446557192.096968.jpg
I also found the expected rust
Name:	ImageUploadedByAirstream Forums1446557468.786383.jpg
ID:	251602Click image for larger version
Name:	ImageUploadedByAirstream Forums1446557547.276472.jpg
ID:	251603Click image for larger version
Name:	ImageUploadedByAirstream Forums1446557571.963925.jpg
Finally, I continue to collect old rusted screws bolts and nuts
Name:	ImageUploadedByAirstream Forums1446557645.535432.jpg
Bullit
Old 11-04-2015, 04:02 PM   #40
Bullit's Avatar
1971 18' Caravel
Worked on a smaller gantry for the rotisserie. You don't realize how handy it would be to flip the frame until your underneath it. Nuf sed
C channel/U channel replacement cole3444 Repairing/Replacing Floor &/or Frame 11 04-17-2019 05:20 PM
Have you seen this 1948 Airstream WeeWind on bus chassis Zed2 Our Community 1 05-27-2004 02:06 PM
Have you ever seen...? COArgosy78 General Repair Forum 2 09-15-2003 09:03 AM
I have never seen an Airstream like this one ... Porky Pig All Squarestream Trailers 10 07-12-2003 07:18 PM
Have you ever seen one of these Dave Bowers On The Road... 7 01-11-2003 12:37 PM
