Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 11-05-2015, 05:56 PM   #41
Bullit's Avatar
1971 18' Caravel
Nokesville , Virginia
May have over done the smaller rotisserie gantry
Name:	ImageUploadedByAirstream Forums1446771203.978173.jpg
Bullit is offline   Reply With Quote
Old 11-05-2015, 06:21 PM   #42
Bullit's Avatar
1971 18' Caravel
Found the first picture I posted
Name:	ImageUploadedByAirstream Forums1446772853.766673.jpg
Old 11-05-2015, 06:29 PM   #43
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
the "camo" look
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 11-08-2015, 04:32 PM   #44
albert's Avatar
1970 29' Ambassador
1959 22' Flying Cloud
1957 26' Overlander
Ashland , Oregon
Send a message via AIM to albert Send a message via Yahoo to albert
I have seen the C channel, and it is Grand!!!
Can anyone suggest the method for taking a floor out of my 57 over lander! It has those sunken elevator bolts and isn't really rotted in any spots that I can find. Do I cut into the floor and start pulling it out? Is there a way to get those bolts out from the top side? I am currently not planning on doing a shell off. Thanks for help.
albert is offline   Reply With Quote
Old 11-09-2015, 04:44 AM   #45
Bullit's Avatar
1971 18' Caravel
Possibly, I have been working on the trailer and need to get some things done before it gets to cold
Old 11-09-2015, 04:47 AM   #46
Bullit's Avatar
1971 18' Caravel
Albert,
There are lots of resources on this forum for doing a floor replacement without taking the shell off. If the floor is not rotted, why take it off?
Old 11-15-2015, 02:50 PM   #47
Bullit's Avatar
1971 18' Caravel
Well the beat goes on. The floor has been removed, the frame flipped and belly pan removed and the flipped again. Next step is solidifying the plan for the frame and off to the trailer frame builder.
Just in case anyone has some doubt, I am a complete novice. No real mechanical skills etc. i continue to do things with this trailer that I would think are way beyond my ability. Short story is "just do it". if you argue your limitations surely you will have them (Richard Bach, Illusion). Nuf sed. Click image for larger version
Name:	ImageUploadedByAirstream Forums1447624165.597328.jpg
ID:	252118Click image for larger version
Name:	ImageUploadedByAirstream Forums1447624182.247603.jpg
ID:	252119Click image for larger version
Name:	ImageUploadedByAirstream Forums1447624197.483969.jpg
ID:	252120Click image for larger version
Name:	ImageUploadedByAirstream Forums1447624216.600167.jpg
Old 06-09-2016, 03:24 PM   #48
Bullit's Avatar
1971 18' Caravel
The frame is off to the welder for almost complete re-fabrication; went with a much taller frame for many reasons (see my replacement frame post)
Name:	ImageUploadedByAirstream Forums1465506184.421733.jpg
Name:	ImageUploadedByAirstream Forums1465506199.813993.jpg
ID:	264075Click image for larger version
Name:	ImageUploadedByAirstream Forums1465506211.406542.jpg
My welder is great, and he lets me help.
Many great people giving great advice makes the unknown a lil easier to navigate. That said, I also began straightening my banana wraps in prep for the rebuild. Like most people the wraps take some abuse and I thought I would have to find some replacements. I thought I should try to fix them before buying something else. I used Aerowoods wood block method and touched them up with a body hammer and dolly.
Name:	ImageUploadedByAirstream Forums1465506489.833606.jpg
Started out small and that seemed to go well
Name:	ImageUploadedByAirstream Forums1465506525.724008.jpg
ID:	264081Click image for larger version
Name:	ImageUploadedByAirstream Forums1465506912.041532.jpg
So well that I started marking out the dented areas
Name:	ImageUploadedByAirstream Forums1465506949.324420.jpg
Name:	ImageUploadedByAirstream Forums1465506975.761378.jpg
Took some work and adjusting here and there but it went surprisingly well
Name:	ImageUploadedByAirstream Forums1465507036.533140.jpg
Name:	ImageUploadedByAirstream Forums1465507054.814825.jpg
Name:	ImageUploadedByAirstream Forums1465507076.427315.jpg
See Aerowoods Full Monty post. Should be compulsory text for this course. He basically makes a wood form and the sandwiches the wrap between the two halves. I cannot do his work justice and strongly suggest anyone attempting this read his posts. He is my metal workin hero. Thank you. It is with the advise of people like him and many others on this forum that I forge ahead.
Thanks again
Old 06-09-2016, 03:35 PM   #49
Bullit's Avatar
1971 18' Caravel
This is the "Stuff" I used on the wraps
[ATTACH]264094[/ATTACH
Thanks again Aerowood (I think that's the way it's spelled).
Name:	ImageUploadedByAirstream Forums1465508075.879161.jpg
C channel/U channel replacement cole3444 Repairing/Replacing Floor &/or Frame 11 04-17-2019 05:20 PM
Have you seen this 1948 Airstream WeeWind on bus chassis Zed2 Our Community 1 05-27-2004 02:06 PM
Have you ever seen...? COArgosy78 General Repair Forum 2 09-15-2003 09:03 AM
I have never seen an Airstream like this one ... Porky Pig All Squarestream Trailers 10 07-12-2003 07:18 PM
Have you ever seen one of these Dave Bowers On The Road... 7 01-11-2003 12:37 PM
