Old 05-17-2015, 05:52 PM   #29
Bullit's Avatar
1971 18' Caravel
Nokesville , Virginia
After a long delay I got back to work today... A little. Drilled more rivets and and removed the vent fan and separated the A/C unit. Can't figure out how to get the A/C down but I need to build a gantry anyway. That's all for now
Bullit is offline   Reply With Quote
Old 05-18-2015, 05:28 PM   #30
Bullit's Avatar
1971 18' Caravel
A/C is off! It wasn't pretty but it's done. No damage to the AS, the A/C ( not that it mattered) or me.
Name:   ImageUploadedByAirstream Forums1431991654.114407.jpg
Name:   ImageUploadedByAirstream Forums1431991672.828093.jpg
Old 07-04-2015, 01:43 PM   #31
Bullit's Avatar
1971 18' Caravel
Still plotting along, first Gantry is up with another to follow. Will need to work more on cleaning the area around the former A/C. Sorta feels pretty good to get started on the next big thing. Click image for larger version
Name:	ImageUploadedByAirstream Forums1436038979.328000.jpg
Slow going but good times ahead....
Old 10-24-2015, 03:57 PM   #32
Bullit's Avatar
1971 18' Caravel
Back to it. Gantries are in place and have begun to brace the interior for lift off. Click image for larger version
Name:	ImageUploadedByAirstream Forums1445723423.099077.jpg
Also took off the 4 corner banana wraps. Belly pan must be full as wellClick image for larger version
Name:	ImageUploadedByAirstream Forums1445723528.539630.jpg
Front street side
Name:	ImageUploadedByAirstream Forums1445723618.213452.jpg
ID:	250960rear curb side
Name:	ImageUploadedByAirstream Forums1445723655.467487.jpg
ID:	250961front curb side. I noticed the curb side lower and mid panels are double hung. The bottom edge of both lower panels can be seen in the last photo.
Anyway body should pop in the next two weeks.
Old 10-27-2015, 01:00 PM   #33
Bullit's Avatar
1971 18' Caravel
I have seen the C channel, and it is Grand!!!
Though I have read it is not necessary I put in some bracing in today. Should be really close to lift off.
Old 10-27-2015, 01:08 PM   #34
Bullit's Avatar
1971 18' Caravel
Forgot the picsClick image for larger version
Name:	ImageUploadedByAirstream Forums1445972891.450857.jpg
Old 10-31-2015, 05:37 PM   #35
Bullit's Avatar
1971 18' Caravel
Popped. Click image for larger version
Name:	ImageUploadedByAirstream Forums1446334544.680892.jpg
ID:	251446Click image for larger version
Name:	ImageUploadedByAirstream Forums1446334572.480874.jpg
Body us all strapped down. Now back to the mouse works and insulation. Should be another long day tomorrow
Old 10-31-2015, 07:21 PM   #36
mapleton , Utah
Houston, we have lift off! This is where the fun really starts. Plan now for your final design concept and place your grey, black and fresh water tanks while you repair the frame and floor. It will save you a whole lot of headaches later. BTW that polish is looking AWESOME!!
tim
rumrunner is offline   Reply With Quote
Old 11-01-2015, 04:03 PM   #37
Bullit's Avatar
1971 18' Caravel
Well, I thought removing the interior was rough... Getting the C channel and "A single" floor section off was as bad. That being said, the C Chanel is in pretty good shape which is a good thing 'cause making templates from my floor ain't happnin. C channel has been mounted on 1/4 plywood for later use on templates.
The floor is a mess
Name:	ImageUploadedByAirstream Forums1446418543.616730.jpg
The back has the expected rot...
Name:	ImageUploadedByAirstream Forums1446418587.386109.jpg
The front was also pretty rotted
Name:	ImageUploadedByAirstream Forums1446418669.558919.jpg
Got the front off.
Lastly, what does everyone else do with all the cool AS Souvenirs you get from doing the full monte?
Name:	ImageUploadedByAirstream Forums1446418793.948004.jpg
Good times, Good times.
Thanks again to everyone who has gone this way before. I depend on the forum to remain motivated!
Old 11-01-2015, 04:36 PM   #38
Central , Mississippi
Good looking progress.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 11-03-2015, 06:35 AM   #39
Bullit's Avatar
1971 18' Caravel
The progress continues
Name:	ImageUploadedByAirstream Forums1446556620.498798.jpg
Special thanks goes out to whoever came up with this methods for hole sawing around the elevator bolts. Click image for larger version
Name:	ImageUploadedByAirstream Forums1446556718.756452.jpg
If there is any doubt about Colin Hyde's explanation of why water gets into the back of 70s trailers, here it is (as I understood it)
Name:	ImageUploadedByAirstream Forums1446557027.082864.jpg
That 4 inch aluminium plate to the left of the bumper literally collects and directs water under the body
Name:	ImageUploadedByAirstream Forums1446557192.096968.jpg
I also found the expected rust
Name:	ImageUploadedByAirstream Forums1446557468.786383.jpg
ID:	251602Click image for larger version
Name:	ImageUploadedByAirstream Forums1446557547.276472.jpg
ID:	251603Click image for larger version
Name:	ImageUploadedByAirstream Forums1446557571.963925.jpg
Finally, I continue to collect old rusted screws bolts and nuts
Name:	ImageUploadedByAirstream Forums1446557645.535432.jpg
Bullit
Old 11-04-2015, 04:02 PM   #40
Bullit's Avatar
1971 18' Caravel
Worked on a smaller gantry for the rotisserie. You don't realize how handy it would be to flip the frame until your underneath it. Nuf sed
Old 11-05-2015, 05:56 PM   #41
Bullit's Avatar
1971 18' Caravel
May have over done the smaller rotisserie gantry
Name:	ImageUploadedByAirstream Forums1446771203.978173.jpg
Old 11-05-2015, 06:21 PM   #42
Bullit's Avatar
1971 18' Caravel
Found the first picture I posted
Name:	ImageUploadedByAirstream Forums1446772853.766673.jpg
C channel/U channel replacement cole3444 Repairing/Replacing Floor &/or Frame 10 01-31-2014 07:50 PM
Have you seen this 1948 Airstream WeeWind on bus chassis Zed2 Our Community 1 05-27-2004 02:06 PM
Have you ever seen...? COArgosy78 General Repair Forum 2 09-15-2003 09:03 AM
I have never seen an Airstream like this one ... Porky Pig All Squarestream Trailers 10 07-12-2003 07:18 PM
Have you ever seen one of these Dave Bowers On The Road... 7 01-11-2003 12:37 PM
