Old 08-18-2014, 09:00 AM   #1
PA BAMBI II's Avatar
1964 17' Bambi II
Strasburg , Pennsylvania
How to rivet original aluminum "bulkhead molding"
Starting to reinstall walls in the Bambi II. Several were held in place with what VTS calls "bulkhead molding:
Bulkhead Moulding
The original moldings were more of a T shape and there is very little shoulder to rivet to the trailer. I guess the biggest issue is getting the nose of the pop rivet gun down onto the shoulder because of the actual extrusion that holds the wall. Is there a way to do this, or should I just screw this trim to the wall?
That is what I have done so far, but I know that rivets have superior holding power.
Thanks- Ben
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
Old 09-04-2014, 05:37 PM   #2
Airline's Avatar
1972 29' Ambassador
grants pass , Oregon
Hi Ben
on my '72 Ambassador,they are screwed ,not rivited.I bought some nice stainless screws after polishing the moulding.
hope this helps !
1972 Ambassador Itn'l 29'.Custom Interior
1987 Avion 34X
1985 Avion 30R
Airline is offline   Reply With Quote
Old 09-04-2014, 05:59 PM   #3
reinergirl's Avatar
Hollis , New Hampshire
When we did this on my sisters trailer, I made little wedges out of aluminum. That and bending the pin helped. As did buying a Sears riveter that had a smaller head. It's doable with rivets! I'd worry about screws working loose.....
My sis wrote about it here;
The Midllife Crisis - 1960 Airstream Restoration: November 2011
reinergirl is offline   Reply With Quote
Old 09-04-2014, 06:03 PM   #4
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Yep I used rivets as well on my 69 ambassador.
Silverflames is offline   Reply With Quote
Old 09-04-2014, 06:34 PM   #5
surfpod's Avatar
1976 23' Safari
1962 22' Safari
1961 16' Bambi
Philly burbs , PA
Little nut on the rivet
I tried this method with some success. A PITA!! Gone through a few rivet guns, too!
surfpod is offline   Reply With Quote
"silver avion" avion C11 airstream "truck camper' "slide-in" aluminum eBay Watch Airstreams on eBay 0 09-14-2013 06:20 PM
T-Molding (Tee Molding) Trouble and Solution! shane_franz Cabinets, Counter Tops & Furnishings 0 07-05-2013 12:09 PM
Plastic insert in aluminum bulkhead edging cuckosnest General Interior Topics 1 06-20-2011 06:02 AM
Exterior Molding-Original?? sailorii 2001 Safari 0 08-21-2009 07:15 AM
