Old 11-07-2004, 08:26 PM   #1
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
How to repair inner fiberglass cap?
Here's a pic of a nasty crack on my fiberglass cap. The rivets have stopped the cracking from getting worse, but how would one go about repairing this? My father who does body work on cars suggested a fiberglass patch. Any thoughts on this technique or any others?
Thanks in advance,
Mike
http://www.airforums.com/photo...php/photo/7270
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 11-08-2004, 10:35 AM   #2
[QUOTE=mello mike]Here's a pic of a nasty crack on my fiberglass cap. The rivets have stopped the cracking from getting worse, but how would one go about repairing this? My father who does body work on cars suggested a fiberglass patch. Any thoughts on this technique or any others?QUOTE]
Mike, glassfiber repairs are quite straightforward, but a patch on the visible side would be obvious. A patch on the back would be elegant, but a lot of work. I would try to work out why the cracking occurred (unbalanced wheels?), and then cover the damage in some way. I can't tell from the photo how high the damage is, but how about a hardwood pad for a speaker or a light fitting, or a shelf? Only you would know! (Oh, and several thousand of us on the forum.) Nick
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 11-08-2004, 01:42 PM   #3
fireflyinva's Avatar
1961 22' Safari
Vienna , Virginia
Dear Mike,
I can't figure out what your "cap" is. It's also not clear where the rivets attach to, since there's no way to tell where the crack is in the trailer.
I had a similar crack in our tub. It wasn't riveted, though. Repairing it took a bit of doing. First we filled the crack in with epoxy putty to provide reinforcement to the patch. Then I put a layer of epoxy, fibercloth and epoxy. I sanded this thing down and realized that I went into the fibercloth. So, did another layer of epoxy, fibercloth and more epoxy. Nick is probably right that it would be more inconspicuous on the back, but this wasn't an option for this repair. I sanded it down smooth, feathering it in with the old finish. Then I painted the whole tub with two layers of epoxy filler paint.
The result? The crack is gone, it is not noticeable at all. I am very pleased with that repair. Then there is rest of the tub--which was crazed with fine cracks. It did not take the epoxy paint well and the result is rather coarse in other parts of the tub. So, I'm going to have to sand it, epoxy the whole darn thing and sand it smooth again, and reapply the epoxy paint. Nevertheless, the whole thing looks nicer in a clean white, even if it's a rough finish in places.
I hope this helps you.
Mary
fireflyinva is offline   Reply With Quote
Old 11-08-2004, 02:29 PM   #4
Craftsman
Guest
Posts: n/a
You might try drilling a1/4" hole at the end of the crack to keep it from running any further, before you patch it.
Old 11-08-2004, 05:57 PM   #5
1961 22' Safari
Vienna , Virginia
That's a good idea about drilling! Wish I had thought of it before my own epic!
One other thing I forgot--wear a respirator! It's not comfortable (your breath will make your chin wet), but the temporary discomfort is much better than the permanent results of breathing in fiberglass particles.
TTYL,
Mary
Old 11-10-2004, 09:29 PM   #6
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Originally Posted by fireflyinva
Dear Mike,
Mary
Mary,
This link has a pic which puts it in perspective.
http://www.airforums.com/photo...00/ppuser/5661
Mike
1958 Overlander
4CU 1st VP
Alternate exterior plastic parts repair IPM Bumpers & Bumper Storage 3 11-12-2013 09:03 PM
Water Fill Cap Stuck 66Overlander Fresh Water Systems 20 09-30-2004 04:48 AM
Bellypan Rivet Repair 66Overlander Belly Pans & Banana Wraps 19 09-15-2004 02:58 PM
End cap repair CO_Don General Interior Topics 2 08-04-2003 03:28 PM
front, end cap George Ribs, Skins & Rivets 9 04-07-2003 04:48 PM
