Old 09-16-2007, 02:20 PM   #1
wannaroam's Avatar
1978 31' Excella 500
Harmony , Pennsylvania
Images: 36
how to remove towel bars?
Can anyone give me a tip on how to remove the towel bars in my center bath Excella 500? Based on the back of the soap holder that I can see inside the bath cabinet, it looks as though they are held in place by a hex nut on the back of the shower wall.
I don't want to tear out the walls to get them out.
Any ideas?
wannaroam is offline   Reply With Quote
Old 09-16-2007, 02:50 PM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Any ideas?
Hi Wannaroam, Is there a small set screw on the underside of the arms attached to the walls? If so, loosen this screw and remove the arms giving you access to the mounting plates. Then remove the plates.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 09-16-2007, 04:40 PM   #3
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
Don't know if this will help but if you did not see a screw on the outside is there a seam that can be pried apart that may be snapped together over the actual screw into the wall? That is the way we got at our new shower bar. There was no visible access in the outer casing.
EDIT: I see upon rereading now that it is visible and Lee had it handled.
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 09-16-2007, 05:20 PM   #4
wannaroam's Avatar
Images: 36
Thanks guys; I will look again (though I didn't see anything before. )
I hope that is the case, it would sure simplify things.
Old 09-16-2007, 06:10 PM   #5
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
the set screw is very small and can be hard to see. A crow bar will work
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 09-18-2007, 06:45 AM   #6
wannaroam's Avatar
Images: 36
Ok, I checked this out and having gotten nowhere, I called my husband to help. He confirmed that there was no set screw to be found. They apparently do bolt in from the back so we were forced to cut them off the wall.
Old 09-19-2007, 03:56 AM   #7
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
I've done a lot of remodeling in my time and I've never seen a towel bar that bolts on from behind with no way of taking it off from the front. Try grasping both end parts that stick out from the wall - thumbs on the under side of each and lifting up and back towards the wall. I have seen them mounted by just hooking over the top of the screwed on wall bracket and then snapping in place over the bottom of the bracket.
Old 09-19-2007, 03:31 PM   #8
wannaroam's Avatar
Images: 36
Gary
Well it makes no sense to me not to have some access to these from the front, but we couldn't see it. Luckily we don't want to keep them anyway so the hubby used a saw and got them off.
secret towel bar? RevBec 1990 - 1993 Excella 10 08-18-2009 06:31 PM
Towel rack inside shower? altamont Sinks, Showers & Toilets 1 02-27-2007 05:19 PM
'66-'68 glass bars brandok Windows & Screens 3 02-13-2007 10:40 PM
weight distributing bars/trunnion bars teutonik Hitches, Couplers & Balls 2 12-04-2003 06:58 AM
Equalizer bars...need one. boltos Hitches, Couplers & Balls 3 09-26-2003 09:21 AM
