11-20-2016, 02:22 PM
1977 31' Excella 500
NEW HARTFORD
, Connecticut
How to remove interior ceiling skin???
I can't figure out how to get this metal edging off, aside from trying to force it with hammer and spackle knife. That's not working so well...
Please help.
11-20-2016, 02:51 PM
1973 31' Excella 500
Vicksburg
, Mississippi
You have to bow the center skin down and then slide one edge out of the track. You don't have to remove the trim to remove center skin. You have to remove center skin then trim, the trim is riveted to the ribs under the center skin.
11-20-2016, 03:11 PM
1973 21' Globetrotter
Houston
You should be able to either bow the center section down as described above, or slide the entire section out one end or the other. Do not get rough with the "edging," as it it unobtainium and cannot be purchased new.
good luck!
11-20-2016, 08:49 PM
Fonthill
, Ontario
Just be warned when We took ours down, we were showered with 40yrs of mouse droppings! Would strongly suggest eye and respiratory protection.
Although it seem like I know what I'm doing, I'm just standing on the shoulders of giants who have done this before and kindly posted their journey.
Cheers,
Jack
73's VE3ZPW
11-21-2016, 09:17 AM
NEW HARTFORD
, Connecticut
I know right!?? That's why I stopped last night. Gotta go to Home Depot and get one of those haz mat suits. Blehhhghh
11-21-2016, 09:19 AM
NEW HARTFORD
, Connecticut
good luck!
I did get a little rough at the end but shouldn't be irreparable. Thanks for the tip!
11-21-2016, 11:10 AM
1967 26' Overlander
Spartanburg
, South Carolina
Please help.
Can't tell much from the pic.
11-21-2016, 12:11 PM
1984 31' Excella
1976 Argosy 24
Olsburg
, Kansas
Dido to what others said about removing upper middle panel. It is nice to have other hands helping when bowing the panel down to take off, don't need to crimp aluminum panel. Good luck. Hazmat suite should work well.
01-07-2019, 03:46 PM
1973 31' Sovereign
Austin
, TX
I used the strategy listed in this thread, bowing the middle down and pulling it out. However it will only come out on one side, the entire length of the ceiling. There's no rivets that I can see (or access) that would be holding the other side in. Any ideas ?
01-08-2019, 08:21 AM
Houston
Try sliding a putty knife between the skin and the mouldingfor the entire length. If there is a hidden rivet, burr, or adhesive, you should find it this way.
good luck!
01-09-2019, 04:12 PM
1973 31' Sovereign
Austin
, TX
I sprayed WD-40 in from the top and bottom. After a while I was able to get it out but it still required a fair amount of force
