Old 12-26-2002, 12:48 AM   #1
NewStreamer's Avatar
Question how to remove ceiling lights
Would like to remove those lights, but can't see any screws
Ron
NewStreamer is offline   Reply With Quote
Old 12-26-2002, 02:27 AM   #2
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Lightbulb Answer
RON,
YOU Should know by now:
IT takes two engineers to do the job~!~
But, if you only have one..that'll work..
LMAO
ciao
(btw, would it help if you turned the "light" on??)<smiles>
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 12-26-2002, 05:10 AM   #3
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Ron,
Depening on style there are two slighlty diffrent methods.
If you have the big square fixture that covers the vent, remove the light switch knob by unscrewing, there should be a keeper nut/ring under it. You need to remove this keeper nut as well as the keeper nut on the fan switch. This will allow the lens to come off. Then the fixture is screwed to the roof. If you have the round fixtures with the switch in the center, uncrew the knob and remove the keeper nut/ring. The lens should now be free and the base is held to roof by screws.
If you are looking at the wall mounted reading lamps the trick is to flex the cover to pop it out. There are no screws. You need to be gentle as these get brittle and you can break it removing it.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 12-26-2002, 08:11 AM   #4
Italiano,
Glad you got a chuckle from my question
64,
the ceiling fixture is square with a round knob in the center. I see
no screws and if I turn the knob it just lights up. I have that same light over the kitchen sink.
Anyway once removed, I would like something more efficient, any
suggestions??
Ron
Old 12-26-2002, 08:40 AM   #5
1984 29' Sovereign
Savannah , Missouri
Question Helpful
Ron...
I figured you must be fustrated and, need the laughter..It makes you look at a problem with a different frame of mind..I hope it worked~! <smiles>..
I wish you luck on IT..
I don't have one of those "vintage streamers".
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
Old 12-26-2002, 08:43 AM   #6
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Thread on better lighting
Streamer, see this thread on improved lighting with Halogens.
http://www.airforums.com/forum...halogen+lights
smily is offline   Reply With Quote
Old 12-26-2002, 08:52 AM   #7
Thumbs up
53,
I can't wait to be your neighbour your pics are killing me
Smily,
Thanks for the thread, most interesting, halogens seem to be what I want.
Ron
Old 12-26-2002, 10:46 AM   #8
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Ron,
Try turning the know counterclockwise, or the oppisite way you turn on the light. The knob should come off, it is threaded on with a left hand thread. looking at the light covers on Inland RV's site they all have a hole for a switch. This switch is what usally holds the cover on with the keeper nut.
Brett G
Old 12-26-2002, 04:01 PM   #9
IKEA halogen lights
Ken,
I called IKEA for buying some of their halogen lights like UWE and others mentioned and I liked the price. It was only $9.95 for a pack of two small halogen lights which is very reasonable.
However the shipping was a minimum of $18. If I got either two or 4 lights the shipping would be equal to cost of the lights (or 2X cost for only 2 lights). Rep said they have a contract with UPS and that is the only alternative.
The closest store is in Virginia close to D.C.
Sure thought it was a deal.
Sav'h Steve
Sav'h Steve is offline   Reply With Quote
Old 12-27-2002, 07:53 AM   #10
Still Working
smily's Avatar
1994 36' Classic 36
Halogens for everyone
Dont know why anyone would just use the Ikea lights.
You can buy an array of 12 volt halogen lights from Home depot, Lowes, and almost any hardware store not to mention your local lighting showplaces.
My lawn lights are all 12 volt halogen.
Point being, 12 volt Halogen lights are alomost as common as incandescent bulbs these days.
Replacement bulbs for my lawn lights are about 10 dollars for a three pack.
Happy shopping,
Smily
Old 12-28-2002, 04:19 PM   #11
Question Halogen lights?
For those of you familiar with the lighting fixtures in my trailer, could you please shed some light on replacing my fluorescent bulbs with halogen bulbs?
I'm familiar with halogen bulbs and understand they create some heat, but are they safe to use in my current fixtures?
John
John is offline   Reply With Quote
Old 12-28-2002, 04:39 PM   #12
correction
I'm not familiar with halogen bulbs..........
Old 12-29-2002, 07:00 AM   #13
Still Working
smily's Avatar
1994 36' Classic 36
Flourescent lights
Flo. Lights typically have a "starter" or a capacitor that stores the voltage until it is built up to a higher voltage, that when released will ignite the flourescent gas within the tube. once the gas is ignited, it takes very little voltage to maintain the ignited gas.
With that being said, no, you cannot use the same fixture for a halogen bulb.
Halogen bulbs require a Halogen fixture. These fixtures typically are constructed of high temperature componenets. Halogen lights get very hot!
If you use the correct fixture and locate them where they will not ignite flammable items such as curtains or paper towel holders, you should be okay.
Smily
Old 12-29-2002, 08:17 AM   #14
Thanks!
I'll just keep what I currently have. Thanks for answering my question!
John
Running Lights Joe Z Lights - Interior & Exterior 7 12-11-2003 08:48 PM
Rear Indicator Lights Cracker Lights - Interior & Exterior 7 11-03-2003 02:42 PM
running lights mazda997 Electrical - Systems, Generators, Batteries & Solar 0 08-27-2003 08:55 PM
looking for brake lights and back up lights larrylisa Lights - Interior & Exterior 6 12-07-2002 06:43 PM
Trailer lights Dbraw Electrical - Systems, Generators, Batteries & Solar 1 09-13-2002 04:51 PM
