Old 10-26-2013, 03:14 PM   #1
tripnfall76's Avatar
1966 22' Safari
saint louis , Missouri
How to remove bathtub?
I have a 1966 safari and as of this afternoon I have the bathroom tub/sink/toilet fiberglass form removed from the wall. But how on earth do you get it out the door? It's too large no matter which way I turn it. Did they set the shell on top after setting the bathroom in LOL? It's one big huge piece and no way is it fitting through the door as it is.
tripnfall76 is offline   Reply With Quote
Old 10-26-2013, 03:23 PM   #2
aquinob's Avatar
Portsmouth , Virginia
Pix would help. Are you sure its all one piece? Generally everything in the trailer originally fit through the door.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 10-27-2013, 10:16 AM   #3
panheaddale's Avatar
1964 26' Overlander
1968 30' Sovereign
somewhere , Tennessee
The door to the bath or the frt. door? If the bath door you may have to take some walls out but it should fit out the frt. door.The sink should separate from the shower and toilet, then you should be able to get it out the door. I just disassembled one on a 1964 overlander and I think they are generally the same. They were put together from the rear forward at the factory so you are trying to take out the first thing put in. Hope you get it out without mush more trouble.
panheaddale is offline   Reply With Quote
