Old 07-15-2014, 04:47 PM   #1
PA BAMBI II's Avatar
1964 17' Bambi II
Strasburg , Pennsylvania
How to prep Zolatone for paint?
The subject line asks it all...we are about to embark on painting the interior of the Bambi II...there is enough wrong with the original Zolatone that we are choosing to paint a silver color with Rusoleum paint.
We are wondering what is the best method to prep the Zolatone for paint? Seems to me that it is pretty well "stuck" to the aluminum...but how to best get paint to stick to it? I think it is probably a good primer in itself, but wondering what your experiences are?
Thanks-
Ben
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
Old 07-15-2014, 05:45 PM   #2
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Priming for Paint
Ben...I'm sure some of the experts will weigh in but I'll give you my experience with priming; albeit not over Zolatone. We have used any number of primers to cover the vinyl clad Airstreams. The primary difference between Zolatone and the vinyl is no "off gassing". I would think you are in a good position to have better result because of this. Getting lasting results painting vinyl covered walls is tricky at best. But we have had good success using a product from Benjamin Moore called Stix. It might well work over the Zolatone.
Regardless of the surface to be painted, good preparation is the key. Any loose Zolatone will need to be scrapped, sanded, and removed. The surface should be scuffed to provide better adhesion. Be careful when using products such as TSP to clean and degrease. Some primers state on the label that they are not to be used over TSP cleaned surfaces (Zinsser primers comes to mind). Many on the forums have re-zolatoned their trailers. I would use your primer of choice and coat with the paint you like. Perhaps you could post pictures of your progress...
Indiana, PA
TAC PA-5
WBCCI 4871
Roadrunner is offline   Reply With Quote
Old 07-15-2014, 07:55 PM   #3
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Hi Ben,
I used Zinsser oil based primer tinted gray for my walls. (over the nasty Zolatone).. I used a pewter colored Rustoleum paint that I applied with a foam brush (I think)...It's really very tuff stuff! They have quite a few colors of this paint. Glad you're making lots of progress, Ben!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
how to prep for paint? teleguy General Interior Topics 9 04-15-2013 08:53 AM
Paint prep and methods Dan S All Argosy Trailers 3 06-27-2010 09:46 PM
70's AS asphalt-based frame paint prep for POR-15 Wabbiteer Repairing/Replacing Floor &/or Frame 1 10-09-2006 08:23 AM
Prep for Zolatone fireflyinva Upholstery, Blinds, Walls & Interior Finishes 15 05-09-2005 08:47 PM
Zolatone Paint Question ALANSD Upholstery, Blinds, Walls & Interior Finishes 3 03-05-2002 03:25 PM
