Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 03-03-2006, 01:36 PM   #1
Zeppelinium
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
How? remove top interior skin
My forum seach didn't find any hints on how to get the top skin loose. I need to remove the upper streetside skin to get at a leak. The channels on either side of the top skin are on tight, don't want to mallet them off until I know that's the right thing to do.
If I wanted to replace the skin, is there a close fascimile for the coated interior skins from the 70s? I'm thinking I want to close off the Vista View windows--where I go you want insulation, not light. Anyone want the glass? I await comments saying this is not a good idea. Anyone done it?
While I'm asking questions, is there a replacement source for the edge trim on the aluminum where it meets the end caps?
Thanks in advance, Roger
Current 6-word memoir: Vintage Airstreams: Four are not enough.
www.mindseyephoto.com www.airstreamdoctor.com
Old 03-03-2006, 02:05 PM   #2
Chuck
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
Are you talking about the ceiling panel, and the associated "rails" on either side of it, in which you can not see any rivets? You might need to take that down first, in order to access the top of the wall panels. If that's what you're talking about, you can remove the ceiling panel by drilling out all the rivets you can see, and removing all the light fixtures, etc, that are attached through it. then, with some help, you can probably get the panel to bow enough without creasing it to get it to pop out of those long channels. With the ceiling panel removed, you'll see how the chanel is riveted on to the ribs; there's an "extension" that is hidden by the ceiling panel that is riveted to the ribs; once the panel is out, you can drill out those rivets, and take the channels down out of the way.
Or, you could do like I did, and just use a putty knife tucked up between the chanel and the ceiling, and tap it with a hammer to break off the rivets. after I got it apart, I realized that this probably wasn't necessary. Oh, well. live and learn....didn't break anything. it was just alot more work than it needed to be....
while you're in there, take a good hard look at any aerial antennas that may be installed. they tend to leak like a sieve.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 03-03-2006, 02:29 PM   #3
Zeppelinium
1977 23' Safari
1975 31' Sovereign
thanks, just what I was looking for. I've Vulchemed the poop out of the seams on that side, but water still leaks out the inside of the side window and runs down the screen. I'm guessing it's the old rotary antenna fixture, maybe the Fantastic Fan, but I don't think so.
Roger
Old 03-03-2006, 03:25 PM   #4
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Roger.
Have you replaced the "sewer vent pipe" gaskets?
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Inland RV Center, In is online now   Reply With Quote
Top 20 Contributors, Top 10 Forums/Threads & New Stats Info.... Andy R Our Community 7 04-01-2008 09:19 PM
Getting on top of it uwe Audio, Video & TV 9 09-25-2006 12:28 PM
Clear coat finish on top James Schmidt Clearcoat, Exterior Paint & Trim 7 06-14-2006 09:26 PM
Leak somewhere in top section- B190 Van Luckydog Sprinter and B-van Forum 2 10-16-2002 08:39 PM
carry a pod on top?? pebblepoint Roof 1 06-28-2002 09:05 PM
