Old 03-28-2006, 10:43 AM   #1
JimGolden's Avatar
1977 31' Excella 500
How much pain?
Ok, I'm looking at doing a full shell off. The question is, how much grief is it to pull the inner skin completely out?
The reason for this would be to replace the old insulation with new.
I have heard many say that's a good way to get any old and musty smells out. I'm thinking this would be a tremendous job. How bad is it? Any brave souls attempt it?
I'm sure it would be easier to rewire it with the inner skin pulled out. But is it really necessary? If my trailer doesn't smell bad, is it wasted work for me to go to this length? Or since I'm ripping it totally apart anyway, is it not that much more? Any brave souls out there do this? How bad was it? What new insulation would I use? Same fiberglass batts I use in the house? Use spray adhesive to hold it in place? Inquiring mind want to know
Thanks!
- Jim
JimGolden is offline   Reply With Quote
Old 03-28-2006, 10:47 AM   #2
Pschoerrn's Avatar
1971 29' Ambassador
Braunschweig , Germany
Yes, we are still into it... and it´s a pain in the a**, but well worth it. With every innershell segment that we removed more and more mice nest were visible and we even didn´t know that there were mice before... We counted 11 upto now and the dirty smell is gone now...
We will put the new insulation in in the next months and will try to make the Airstream mice tight.
I would attempt it and get a new carpet that will help also.
Good luck!!!
Bjoern
Björn H. Adam
Wolfenbuettel, Germany
AirstreamForumsMember No. AIR 5535
Proud Owner of a 1971 Ambassador 29' called "Dave"
-A stranger is a friend you just haven´t met before!-
unknown irish
davetheairstream
Pschoerrn is offline   Reply With Quote
Old 03-28-2006, 11:09 AM   #3
1971 31' Sovereign
Pauma Valley , California
Jim,
They call it the "full monte" when you strip it down like that. Lots and lots of threads and tons of help here....
We have a '71 31' Sovereign that we're attempting to do this on. We've had it a little over a month and all we've done is remove everything, scrub the interior walls and cut out the back end floor. I used a shovel (literally) to shovel out the poop. I was hoping we could skip the interior skin removal...but now Bjorn brings up the mouse problem...well, we may have to remove the interior skins afterall.
DaisyandDave is offline   Reply With Quote
Old 03-28-2006, 11:44 AM   #4
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
It's a lot of work. A lot of work. I've got mine completely apart and am (finally) putting it all back together. There are many opinions and methods of insulating. Same with wiring. My wiring is in very good shape, BTW. IMHO, the only way to get the smells out is to completely gut it, clean it and put it back together. You also get the oportunity to check the "health" of the frame an so on doing a Full Monty. I'll be replacing many of the interior items due to wear and smell.
You can see my thread here. It's a long thread, but maybe something helpful for you there.
http://www.airforums.com/forum...nte-15132.html
Uwe's thread is here. Great work and a lot of inspiration:
http://www.airforums.com/forum...ler-11687.html
JCFerguson has some beautiful wood work and designs here:
http://www.airforums.com/forum...ari-15592.html
Malconium has several very good threads discussing in good techical detail many of the processes of a complete rebuild (insulation, new floor, etc).
NorCal Bambi has some great ideas as well:
http://www.airforums.com/forum...mbi-17925.html
These are just a few of the people that I take inspiration from. There are others that I can't find right away (Moogie32, a-merry-can), and I certainly don't mean to leave anybody out.
It is a lot of work, my problem is that I don't nearly enough time to work on it. I'm ready to take the think camping!
www.nesa.org
Air No. 6427
confused Argosy newbie Dave Cole All Argosy Trailers 23 09-15-2006 09:36 PM
Screen PAIN! mtnman Windows & Screens 6 02-25-2006 09:53 AM
WBCCI questions Kistler Our Community 8 12-09-2002 07:04 AM
What is the MOST you have paid for an AIR STREAM part overlander Our Community 64 11-19-2002 05:15 PM
