Old 04-08-2013, 04:25 PM   #1
Youngstown , Ohio
How is water getting in here?
Started opening things up and for the 2nd year in a row, we have about 2" of water in the little tray compartment behind toilet. Cant figure it out. It all collects in the tray. Floor below is dry. Shower hose doesn't touch it. No cracks in ledge above. Included a pic. Any ideas?
Splinter is offline   Reply With Quote
Old 04-08-2013, 04:54 PM   #2
Youngstown , Ohio
68 Tradewind
Name:	Toilet Compartment.jpg
Old 04-08-2013, 05:21 PM   #3
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Black tank vent pipe seal is my bet.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 04-08-2013, 05:32 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Regards,
JD
That would be my guess too, when was the last time you replaced the vent stack seals?
Aaron
WBCCI #XXXX AIR #2495
Old 04-08-2013, 05:36 PM   #5
kokopat's Avatar
Hendersonville, NC , North Carolina
If it's original, the shower valve has copper pipe soldered to it and could have swollen and burst during a freeze and thus the leak (if the water is on). If you put in Pex as I did then you could have a loose fitting and it will leak into that tray. Also water could come in down that back wall and get into it that way.
Good luck,
Pat
kokopat is offline   Reply With Quote
