Old 02-24-2011, 04:24 PM   #1
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
How does the sofa go together?
I finally assembled my sofa and put on the new cushions. Looks good, but I think something is wrong. The story: I picked up the frame from another Airstream. It was sort of in pieces, and I tried to figure out if I had everything and how some parts went together. I think I got most of it, but it feels a little unstable. Here are my questions/concerns/issues:
1. If you sit on it, back doesn't feel sturdy. I can almost rock in it. A lot of play. Is that the nature of this thing or does it sound like something is missing?
2. How do the armrests go together? When I lined mine up with the sofa, the metal supports and brackets rub into the fabric. I pulled them slightly forward, but that looks odd -- looks like the arms stick out farther than the sofa.
adwriter73 is offline   Reply With Quote
Old 02-25-2011, 06:15 PM   #2
Ottawa , ON
Not sure this will answer your questions, but here is the diagram for the 1974 version of the "lounge" as AS calls it.
Old 02-25-2011, 08:24 PM   #3
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
That appears to be "Jacknife" style couch, where links on side of backrest allow it to flip over and end up extending width of bed in front of seat cushion.. If it is, two bolts on each side of backrest through metal links and two bolts to anchor linkage should keep it firm.. If you re-upholstered arm-rests with new foam or padding, rubbing is likely, and they do look awful puffy and wider than normal.. Armrests not very solid structurally, and easier to move them a little away from sides of unit and re-atttach.. If backrest not solid in place, suspect one or more of the bolts in from sides are not anchored in wooden backing... We also lift top padded portions of armrests off before extending sofa back, and then put them back into position...
When we re-did ours, we did all assembly on couch parts firs, and then put armrest units back in place last...
Condoluminum
Condoluminum is offline   Reply With Quote
Old 02-25-2011, 08:27 PM   #4
Splitrock's Avatar
Sioux Falls , South Dakota
This is how mine looked.
Name:	Sofa frame.jpg
Old 02-27-2011, 09:57 AM   #5
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
I will check the bolts. At first glance, it doesn't appear that anything is loose or missing. But when you apply weight to the back of the sofa, like when you sit down and lean back, it seems to have more "give" than it should. Feels unstable. It's almost like there should be more bracing. I will take a photo of the back and post it.
Old 02-27-2011, 11:24 AM   #6
1972 21' Globetrotter
nc , North Carolina
a 72 i had had a shelf behind the sofa for back to rest on, like a stop. did it have the shelf.
rock60 is offline   Reply With Quote
Old 02-27-2011, 02:13 PM   #7
Islander
kingfisher24's Avatar
2005 28' International CCD
Deer Harbor , ORCAS ISLAND WA
sofa
where would i look for a sofa for a 2008 safarise ?????
Kingfisher24
and the Four P's(Paula, Phoenix and Peabody II and Pearl)…Peabody is here…..
2013 GMC sierra denali
WBCCI 2541
4CU
kingfisher24 is offline   Reply With Quote
Old 02-27-2011, 09:28 PM   #8
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
That would make sense. I got this out of another Airstream that had been gutted, so I'm not sure about a shelf. I can certainly build one if it is supposed to have that.
Old 02-27-2011, 09:29 PM   #9
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Here is a snap shot of the back (I just have the sofa in position, not secured to the floor yet).
Old 02-28-2011, 05:10 AM   #10
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
That is not a sofa from that era of Airstream. The sofa in the 70s did not have a back frame at all. You are working with a much different item.
Richard
Old 03-01-2011, 07:17 AM   #11
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
It is supposedly out of an early 80s model.
couch, lounge, gaucho
The old girl needs new shoes.... Trex 1970 - 1973 Sovereign 1160 03-04-2017 10:39 AM
Classified new listing 03 34 sofa slide tslanier Buyer Guidelines 4 04-02-2011 07:15 PM
64 globetrotter front sofa bed Autumn 1960 - 1964 Globetrotter 26 02-11-2011 03:42 PM
Sofa bed upgrade? hairmac 1966 - 1968 Safari 3 01-23-2011 07:34 AM
Battery switch behind the sofa LawChick Batteries, Univolts, Converters & Inverters 9 01-13-2011 08:52 PM
