Old 01-14-2007, 10:25 AM   #15
NorCal Bambi's Avatar
1963 16' Bambi
Yreka , California
Images: 21
Tim, here is a method that a boatbuilder passed on to me when I was working on the Bambi. Trick is to hold the compass at the same angle while you are making your arch. If you look at my thread you will see pictures of the washer method. The boat builder add a post and gave me this method. It works great.
Don
Name:	1-14-2007 9-18-04 AM_0000.jpg
NorCal Bambi is offline   Reply With Quote
Old 01-14-2007, 11:34 AM   #16
CanoeStream's Avatar
St. Cloud , Minnesota
Cool Use a story stick
Long promised to many on how to duplicate any complex 2-dimensional shape: Story Stick to copy irregular shapes
Tim, I've promised putting the 'story stick' thread together to more people than I care to say. You are the motivation -- thank YOU (and Rob & Colin, et. al.) for all the hard work on The VAP.
5 meter Langford Nahanni
Old 01-14-2007, 09:23 PM   #17
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Wow, that's all I can say!
Thanks to everyone for the great tips. I'm sure I can tackle a bulkhead project now. I realize how difficuilt it is to explain techniques in writing.
Bob, thanks for the nice comments about theVAP! And the follow up with your 'story stick' method. I'm going to experiment with that one as well.
Thanks again everyone!
-Tim
theVAP - Airstream Podcast
Old 01-15-2007, 06:33 AM   #18
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Don
Norcal is righ, boat bulkheads are a harder to do, and a boat is never level. If you do a search for a tick stick it will also help to get the curve correct.
Here is a link to start you off.
Matching Curves With A Tick Stick
I have used this on several boat rebuilds and it works.
Good Luck Jim
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 01-27-2007, 10:15 PM   #19
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Story Stick
After all the suggestions presented here I opted for the Story Stick. I figured it would have the most chance of being success full for a rookie like me .
I ended up using a 5 gallon paint stick and trimed the end down to a point. I taped the paper on the bulkhead where I wanted my panel. You see a white panel there in the photo. That is the one I made that did not fit well enough for me.
Then I reproduced the story stick on my panel and cut it out. It fit much better. I could have made more story stick marks to reproduce it better, but the final product works good.
Thanks to everyone for the help! Here are some photos.
ID:	31414   Click image for larger version
ID:	31416   Click image for larger version
-Tim
Old 01-27-2007, 10:58 PM   #20
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
End of story.....stick. Good job. I spent 50 years building displays and tried most of these suggestions. All can work....it just takes patience.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 01-28-2007, 12:24 AM   #21
1973 31' Sovereign
Portland , Oregon
Images: 22
I think we can now all guess why Airstream used the aluminum channels around the curved bulk head edges (at least they did on my 1973 model). The channel must be something aproaching 3/4" deep. The bulkhead can then easily be cut to the same curve everywhere. It fits into the channel which then attaches to the wall. There can be a gap of at least 1/4" between the bulkhead and the wall that is effectively hidden by the channel. The gap amount can vary quite a bit too without it showing. I am sure that they intended this for another purpose too - namely to allow some flex at the intersection between the bulkheads and the wall but it does do a pretty good job of hiding the gap too while it is at it.
Malcolm
malconium is offline   Reply With Quote
Old 01-28-2007, 06:25 AM   #22
1976 25' Caravanner
Campton , New Hampshire
What I have done is similar to Royce . Find a plastic wheel from a toy or old pulley , about 2" diam , can be larger doesn't matter . Get your pattern material on the wall at least as close as the radius of the wheel . Put a pensil in ther center of the wheel and follow the contour of the wall . The wheel will keep the pensil mark a perfect 90 deg, from the wall . Now take the pattern down and add on enough material to the outer edge to make up the radius of the wheel . Then trace back holding the edge of the wheel on the original trace mark , this will put back the radius distance of the wheel , this then will give you the original wall line . Hope that made sense , it would take about 2 sec. to deminstrate .
ticki2 is offline   Reply With Quote
Old 01-28-2007, 06:42 AM   #23
ticki2 -- Excellent idea! And simple too. Seems to take some of the awkwardness out of the similar compass method. Thanks!
Old 01-30-2007, 11:58 AM   #24
1971 31' Sovereign
Hamilton , Ontario, Canada
Hey Safari
You might want to try this 1.You'll need two sided tape 2. Starting on the outside top leave some tape overhanging then moving in on your curve follow the curve with the edge of your tape at the end your tape should follow the curve 3. Now peel the backing off attach paper to tape following the curve once tape is covered by paper grab the excess you left sticking out at the top and remove your template you now stick it to what you want to cut. I would suggest testing small pieces of different thickness of paper. Just a thought. The beauty is the paper doesnt have to be perfect you can trim it after along your tape .
Atomic#13 is offline   Reply With Quote
Old 01-30-2007, 12:01 PM   #25
1971 31' Sovereign
Originally Posted by Atomic#13
Hey Safari
Disregard all this i just saw that you did the work already lol
Make of your tow vehicle John Community Polls 97 11-24-2011 02:24 PM
The right person does make a difference stinkytwinky Waste Systems, Tanks & Totes 16 09-24-2005 11:53 PM
Gotta make ya grin FrankR Off Topic Forum 9 07-11-2002 12:36 PM
