Old 07-15-2012, 05:37 PM   #1
Silverbee's Avatar
2015 28' Flying Cloud
2012 25' Flying Cloud
2007 20' Safari SE
Fuquay Varina , North Carolina
How do YOU hang pictures on aluminum interior?
Have tried every level of "Velcro" I can find--No real success.
So, if you hang pictures, etc. on your "shiny" interior, what has worked for you?
Silverbee is offline   Reply With Quote
Old 07-15-2012, 05:45 PM   #2
reinergirl's Avatar
Hollis , New Hampshire
Have you tried Command hooks? They only negative I've found is that you can't remove them on a cold surface ( like a window in the northeast during winter)
Product Catalog:*Commandô Products
reinergirl is offline   Reply With Quote
Old 07-16-2012, 11:32 AM   #3
dznf0g's Avatar
Oswego , Illinois
Velcro on the existing (Classic) mousefur for lighter items works well. The 3M "command" products for all smooth surfaces. I have yet to have anything fall from place.
-Rich-
Old 07-16-2012, 01:19 PM   #4
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
...hang pictures, etc. on your "shiny" interior?!
If you must...rivets work.
Shari
Old 07-16-2012, 01:23 PM   #5
Medford , Southern Oregon
Nickle finish Command Hooks
Saw these at Target the other day Amazon.com: 3M Command 17053BN Traditional Large Plastic Hook with Metalic Brushed Nickel Finish: Home Improvement
sakthorp is offline   Reply With Quote
Old 07-16-2012, 01:28 PM   #6
xo1rider's Avatar
2012 27' FB International
Fremont , California
As others have said the 3M hooks - I've hung a clock in both the bedroom and dining area. Even after multiple trips they're solid, never noticed even a little bit of slippage. We've also got them around the kitchen for towels etc..
"The bad news: there is no key to the universe.
The good news: it was never locked."
Swami Beyondananda
http://polakoff.com/RamblinRose/
Our travel log
xo1rider is offline   Reply With Quote
Old 07-16-2012, 02:02 PM   #7
50KIP's Avatar
2009 19' International
Woodinville , Washington
I've had luck with suction cups
DonS
"It's like magic, only real"
(Bud Light commercial)
Women and cats can do as they please, while men and dogs should relax and get used to the idea.(R. Heinlein)
50KIP is offline   Reply With Quote
Old 07-16-2012, 02:06 PM   #8
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Check out the "Industrial Strength" velcro. With hooks things can go flying when underway. They are going no where with the Industrial Strength velcro.
MICHAEL
Old 07-16-2012, 02:38 PM   #9
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Try this
3M automotive body moulding tape. It is a double sided tape. This stuff is typically used to mount the plastic trim to the body of cars.
A little dab will do you!
Available in the auto department at Wal-Mart abou3 $3.00
AtomicNo13 is online now   Reply With Quote
Old 07-16-2012, 02:49 PM   #10
1974 Argosy 20
Kooskia , Idaho
Scotch "Reclosable Fasteners" are great. A bit hard to find, go to a full line hardware store. They look like Velcro, but actually different. They have a very heavy duty adhesive back. Here are the bullets listed on their package for their use. UPC code #5113164254
*Audible Snap indicates closure
*Great for moving or vibrating surfaces
*For indoor or outdoor use.
Old 07-16-2012, 02:54 PM   #11
dznf0g's Avatar
Oswego , Illinois
Some of the command products (not hooks) are snap together...sorta like velcro, but more like little posts that catch each other. With these you can hang stuff tight to the walls with no swinging, like the hooks. The Command adhesive I am sold on. Stays put but easy to pull to remove with no clean up or damage. I have a tin clothes hook/rack which has held 3 hats and 2 hoodies while traveling for over 2 years now. It is held in place with 2 of the command "picture patches" good for 2 lbs each.
-Rich-
Old 07-16-2012, 04:25 PM   #12
alclad's Avatar
1961 16' Bambi
Wilmington , DE
Images: 46
non ferrous magnetic hooks
alclad is offline   Reply With Quote
Old 07-16-2012, 04:58 PM   #13
2010 22' Sport
Carver , Massachusetts
I have had good luck with the velcro like Commands strips. I replaced the backer in some frames with plexiglass and put four strips on the back, one in each corner, and the same on the aluminum and all have stayed on great so far.
etobolski is offline   Reply With Quote
