Old 04-13-2015, 12:24 AM   #15
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I had NO mouse infestation in the walls of my 72 whatsoever, and only under the last sheet of plywood in the floor, and that was minimal.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 04-13-2015, 03:36 AM   #16
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I have a 71 that was a mouse condo when I got it. There still is a hint of Eau de Mickey but it does dissipate over time, a long time. Either that or you just get used to it. The belly pan is the worst offender.
Old 04-13-2015, 05:36 AM   #17
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Use about twenty pounds of baking soda. Distribute heavily in all areas you can later remove it with a good shop vac. Leave it in place for about three days or more, then remove by sweeping up what you can, vacuuming the remaining residue.
Baking soda is one of the best adsorbent other than activated charcoal and is far less messy. I have used this to remove the smell of putrefaction from a carpet, as the result of a small animal dying and.....
Once you have "deodorized " with the baking soda, if the oder remains you will then know the next step is the interior skin removal.
Ms Tommie Lauer
Greensboro, NC
2015 Serenity 30 RB / 2008 Dodge Cummins 4 X 4
WBCCI #4165 AIR #31871
Happy trails and Good Luck
AIR #31871 WBAC #4165 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 04-13-2015, 05:48 AM   #18
1981 31' Excella II
New Market , Alabama
It is not a bad idea to replace the insulation on the lower sections with some rigid foam that won't absorb and hold water. This also gets rid of some of the musty smell. I am working on getting the stale 30 yr old plastic smell out of mine. Painting the floors also seals off much of that smell that has gotten into the floor.
Perry
Old 04-13-2015, 10:41 AM   #19
B00merang's Avatar
2010 20' Flying Cloud
Hailey , Idaho
I'm with AnnArbor Bob...based on my own sad experience what you have left is in floor that got soaked...little by little (literally). Unless you want to rip that up make sure you dry it well...then seal and paint it like you've proposed. It'll take awhile to air it out. You'll get there. jon
B00merang is offline   Reply With Quote
Old 04-13-2015, 10:57 AM   #20
Stanwood , Washington
I would replace the insulation and paint the floors with Kilz.
dfschultz is offline   Reply With Quote
Old 04-13-2015, 12:12 PM   #21
1977 31' Sovereign
Lynnwood , Washington
1) For the musty mouse smell, try putting an ozone machine inside your Airstream for a few days.
2) Mice like to chew on wiring. I've seen this in cars that haven't been driven for extended periods (on the order of weeks to months) I would be more worried about the wiring than the musty mouse smell.
Tom
TomKirk is offline   Reply With Quote
Old 04-13-2015, 07:11 PM   #22
mrrealtor's Avatar
1972 31' Sovereign
Racine , Wisconsin
I'm going to try and mopping the plywood with a concentrated bleach/water mix to see how much it helps.
1972 Airstream International Land Yacht Sovereign
mrrealtor is offline   Reply With Quote
Old 04-13-2015, 07:25 PM   #23
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Also... don't forget.. if your plumbing is dry, there may be some stink coming out of there, too..
Peace and Blessings..
Channing
WBCCI# 30676
Old 04-13-2015, 09:30 PM   #24
mrrealtor's Avatar
1972 31' Sovereign
Racine , Wisconsin
Oooo. Good thought. It is dry. I am going to flush the whole system and see if that helps too!
Old 04-13-2015, 10:26 PM   #25
79nTOW's Avatar
1979 29' Ambassador
Mobile , Alabama
To remove musty smell place aluminum pie plates with dry coffee in them. The coffee will smell a lot better then what you are smelling now. The more the better.
Predeta
79nTOW is offline   Reply With Quote
Old 04-14-2015, 08:56 PM   #26
mrrealtor's Avatar
1972 31' Sovereign
Racine , Wisconsin
Well last night I mopped all the floors with concentrated bleach water. About 90% improvement!
Old 04-15-2015, 03:59 PM   #27
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I love chlorine bleach.
Old 04-15-2015, 04:47 PM   #28
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Great!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Help with musty smell shelleysnyde Airstream Trailer Forums 28 02-20-2015 08:32 AM
Old Musty Smell rebelstand General Interior Topics 29 07-08-2011 04:51 PM
dead mouse smell Globie64 General Interior Topics 2 08-29-2010 09:33 PM
First dog in AS - how do you eliminate that dog smell? Whirlaway The Pet Forum 42 03-22-2010 05:54 PM
