Old 01-26-2007, 11:03 AM   #15
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Most of the voltage meters you buy - I have not seen one without this feature - will have a colored background that shows - HIGH - GOOD - LOW (BAD). In lots of campgrounds where they "UPGRADED" for modern campers the wiring was not done correctly - just new outlets installed. Brownouts and low voltage situations can occur when everybody in the campground turns on their AC units - at the same time. Only so much juice to go around.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 01-26-2007, 11:15 AM   #16
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I have this setup in my trailer. I noticed when I was camping at 29 Palms it did read a little low (under 110). At 18 degrees I don't think many AC units were starting, but plenty of heaters and heat strips were on high.
Richard
Old 01-26-2007, 01:05 PM   #17
bobchevy89's Avatar
1977 24' Argosy 24
Inverness , Florida
I bought my water hose at walmart in the camping isle it is marked for potable water. I have 2 hooked up togtgher. no hose taste . I flush the hose first then hook up.$12.00.. a piece..
just want to camp happy
bobchevy89 is offline   Reply With Quote
Old 01-26-2007, 01:32 PM   #18
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
I purchased a kit that came with a short white potable hose and a carbon/charcoal (?) filter. I hook this to my longer (25' I think) white potable hose. I also use the faucet filter and a pur water filter picture combination for drinking water. But, I haven't noticed any funky taste when I brush my teeth!
Family of Disney Fanatics
WBCCI# 4821
Old 01-26-2007, 01:37 PM   #19
Jacob D.'s Avatar
1964 26' Overlander
Alameda , California
You can't cause any damage to the house you're plugged into by running too much stuff unless their wiring is incorrect in the first place. All that'll happen is that you'll trip their circuit breaker, which is annoying but not dangerous.
I'm a little confused as to how "not enough current" could be a problem for A/C though. It's not like the A/C unit knows how much current is available. It either draws what it needs or it doesn't, and if what it tries to draw is too much, you'll trip the breaker. If it doesn't trip the breaker, I can't see how it could be harmed.
Not enough voltage could cause a problem, but voltage drop shouldn't be a problem at a house with just one additional 15A or 20A load. That's only the equivalent of turning on an electric heater or running a couple of coffeemakers. At a campsite there's more potential for undervoltage, though.
Jacob D. is offline   Reply With Quote
Old 01-26-2007, 02:07 PM   #20
Clayton , North Carolina
The A/C damage is from voltage drop. You can check by checking voltage in the trailer with no load, then with load. If there is more than a 5% drop, you're getting into dark territory.
"Cats are intended to teach us that not everything in nature has a purpose." - Garrison Keillor
Paul NC is offline   Reply With Quote
Old 01-26-2007, 11:01 PM   #21
Since we're on the topic of home hookups, has anyone done a hookup to their sewer/septic? I've got a septic tank and thinking of some kind of way to dump the tanks into it if need be.
Old 01-26-2007, 11:41 PM   #22
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
I have an exterior sewer cleanout that I can remove the cap on and use. It's not in a very convenient location in my yard so I usually take it to the city yard and dump for free.
Dave
Fyrzowt is offline   Reply With Quote
Old 01-27-2007, 09:23 PM   #23
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
Volt Meter
Where did you find the little plug-in meter?
Randy and Pat Godfrey
Region 3 2nd VP, Florida Airstream Club (027)
WBCCI# 7591 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
A journey of a thousand miles begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 01-27-2007, 09:27 PM   #24
2002 25' Safari
Dewey , Arizona
Images: 62
Mine came with the trailer, but you can get one at Camping World for under $20.
AC Voltage Meter - Camping World
Richard
Old 01-28-2007, 10:14 AM   #25
clancy_boy's Avatar
Kiln , Mississippi
Images: 8
Home Depot - costs a little more - I think it was $19.99 - but no shipping if you have to order it from CW - if you walk in it may be cheaper at CW.
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 08:05 PM
'85-34ft Sovereign City Water Hook up E&T Stutts 1984 - 1989 Sovereign 1 10-31-2002 06:31 PM
Power Jack Question 68 Suburban Jacks, Stabilizers, Lifting and Leveling 3 10-11-2002 06:05 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Tire sizing question casarodante Tires 5 07-02-2002 10:19 PM
