Old 08-14-2011, 01:39 PM   #1
Distantdrummer's Avatar
1975 31' Sovereign
Houston , Texas
Lightbulb Homesulate (Insulation)
Have any heard or had experience with this product? (for home or trailer)
I notice their website does not dwell much at all on the R-Value which they tout as equaling R-5.5 per inch, or at least it seems that is what they are saying. But they don't say it very prominently. (I would think that is an excellent result if actually true).
Also they say their product is non-corrosive to wood and steel studding, It would be critical to know if the same non-corrosiveness applies to aluminum.
It is said to not expand inside the wall, just fill and (I guess) firm up to some extent.
HOMESULATE
Wall Foam Insulation for Existing Homes
BTW I find that this forum has no sub-catagory for "Insulation" related threads. It should...mods!
__________________________
____ d'drummer ____
...aahh..rumm..pu..tum..tummm...
Distantdrummer is offline   Reply With Quote
Old 08-15-2011, 12:52 AM   #2
1975 31' Sovereign
Houston , Texas
further info on this type of insulating foam.
TRIPOLYMER FOAM
Tripolymer Description | Tripolymer Injection Foam
Of course my interest is how it might work in an Airstream.
It needs a wall thickness void of about 1" to "flow" downward. What is the void thickness in one of our Airstreams?
However the data video shows it being added to walls that already contain glass batts and it flows down, apparently in front (or back) of the batts.
Might only be feasible for insertion in Airstream walls that have been emptied of the glass insulation. If that's the case we probably won't see much use in our trailers.
Also correction to my above post. The R-value stated is 5.1 per inch (not 5.5)
____ d'drummer ____
Old 08-15-2011, 09:11 AM   #3
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Zero cavity, so that stuffed this idea.
A shame its not available as a DIY product, imagine the stories of good foam gone bad (dibbs on the reality TeeVee Series) from those Weekend 911 calls!
Dow Safetouch insulation 2vets General Interior Topics 3 07-13-2011 07:25 PM
Black adhesive behind insulation. Darkspeed General Interior Topics 2 06-17-2011 10:55 PM
Fiberglass vs Cotton Insulation GeocamperAS General Interior Topics 13 03-09-2011 07:22 AM
Insulation lmassa Belly Pans & Banana Wraps 4 02-24-2011 10:17 PM
Insulation CampUnger General Interior Topics 3 02-13-2011 07:52 PM
