Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 10-19-2003, 06:55 PM   #1
TexasStars
TexasStars's Avatar
Profile:
Help..Wet Carpet
Noticed wet carpet on my 87 345 M/H this weekend while at a Rally, started outside the bathroom and close to rear bedroom and in the morning was wet inside of bathroom. Running rear air all night and having thoughts could be condensation finding it's way inside the walls through a seam maybe ? or water pump line etc. under rear bed, Anyone experience this problem before....
Thanks !!
TexasStars is offline   Reply With Quote
Old 10-19-2003, 07:33 PM   #2
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
I had wet carpet under the AC because A/S hadn't properly sealed the drain line to the AC pan outlet. The drips were so far apart that we didn't notice them happening, but after a few hours, there was an appreciable wet spot.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 10-20-2003, 09:01 AM   #3
wb13798
wb13798's Avatar
Profile:  2004 28' Classic
huntsville , Alabama
my drip hose stopped up. i took a shop vac and succeded in clearing the trash. you can take a hose on the outside of the unit and blow into the pan but that makes a mess . a shop vac with the narrow hose nosel in the pan area to catch the water will work and not too bad a mess. you will have to disassemble the roof unit to do that. that clears all of the crap out .
probably be best to disconnect the drip hose from the pan, if possible. lol
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 trailer
PEGGY SUE security dog
wb13798 is offline   Reply With Quote
Old 10-20-2003, 11:50 AM   #4
TexasStars
TexasStars's Avatar
Profile:
Good advise and this is where I will start and see what happens. Thanks for the responce... I would be lost if it were not for this forum...lol
Wall-to-wall carpet alternative mcneon Upholstery, Blinds, Walls & Interior Finishes 8 09-08-2004 09:08 PM
Putting in new carpet wardster All Argosy Trailers 1 02-03-2004 12:02 PM
Carpet Replacement with wood Roger and Nancy Floor Finishes 32 12-07-2003 11:06 AM
Carpet Squares Don in E Texas Repairing/Replacing Floor &/or Frame 1 07-04-2003 07:43 PM
Carpet Cleaning Advice JaceBeck Upholstery, Blinds, Walls & Interior Finishes 4 03-26-2003 10:25 AM
