Old 03-19-2019, 11:18 AM   #1
Unhitched
2000 28' Excella
1984 31' International
Smithtown , NY
Help ! Insulation adhesive removal - 2000 excella
I have scoured these forums looking for the magic solution to remove insulation adhesive residue on the interior wall ( skins off).
Sadly no magic. We removed interior walls and all the fun pink stuff and left behind is the brown goo liberally sprayed on every visible piece of aluminum. Not sure if this is how they normally install the insulation but someone was very heavy handed with the glue. Besides the annoying pink fibers what is most noticeable is the level of mold that grows in the glue itself. We would have left it except for the level of active mold bar seems to be living in the glue. There were certain bays where they did not useany glue and sure enough the aluminum is brand new, clean, dry ( and most importantly free from mold). Needless to say we wonít be gluing anything when we reinstall insulation.
We tested everything - goo gone, MEC, the heavy duty citrus paint remover. So far the citrus remover works best after sitting for several hours. Because itís so thick it doesnít evaporate like everything else- the longer it sits the better it works but still requires some muscling to get it off. Also we are fighting weather as Iím sure the New York temps are not helping ( a mild 45 for NY nevertheless)
Anyone have any luck with anything else? Was thinking of trying the heat gun but concerned about impacting the exterior finish ( ours has the exterior clear coat we didnít plan on removing it )
Unhitched is offline   Reply With Quote
Old 03-19-2019, 11:41 AM   #2
1972 25' Tradewind
1976 31' Excella 500
Denver , Colorado
Toxic and nasty, but paint remover (not the "natural" kind) is probably your best bet.
25' 1972 Airstream Trade Wind Land Yacht
2006 Jeep Liberty CRD (diesel)
http://BeahmStream.com
kidjedi is offline   Reply With Quote
Remove Insulation Adhesive ASNomads Upholstery, Blinds, Walls & Interior Finishes 12 01-05-2018 10:28 PM
Black adhesive behind insulation. Darkspeed General Interior Topics 2 06-17-2011 11:55 PM
Removing fiberglass insulation adhesive??? wrajr Repairing/Replacing Floor &/or Frame 3 06-09-2010 03:01 PM
Insulation in the walls -- adhesive or no adhesive? wrajr Repairing/Replacing Floor &/or Frame 8 04-27-2010 10:08 PM
dried adhesive removal, again Rog0525 Cleaning, Stripping & Polishing 8 08-18-2002 02:29 AM
