Old 07-04-2014, 08:48 PM   #1
2014 30' International
Round Rock , Texas
Help! Bed is stuck in up position!
We lifted bed to put stuff underneath in storage bins for the night and heard a "click". It is now stuck up in the air. How do we get it back down? Lift mechanism says "master lift" on the side. Is in 30' 2014 Imternational Signature. Thank you!
Honeybadgers is offline   Reply With Quote
Old 07-04-2014, 08:53 PM   #2
dznf0g's Avatar
Oswego , Illinois
Are they gas strut tubes like on your car trunk/hatch?
-Rich-
Old 07-04-2014, 09:00 PM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I don't remember any locking mechanism on the bed lift, it's all done with the "air shock" lifts. Simply push down firmly on the foot of the bed, and it'll close.
Old 07-04-2014, 09:04 PM   #4
dznf0g's Avatar
Oswego , Illinois
It's a 14 model...maybe there was a change
-Rich-
Old 07-04-2014, 09:51 PM   #5
Well Preserved
1993 21' Sovereign
The '15's don't have a lock, either.
Old 07-04-2014, 09:58 PM   #6
dznf0g's Avatar
Oswego , Illinois
Hmm,dunno then. OP heard a click. Broken strut shaft?
-Rich-
Old 07-04-2014, 10:44 PM   #7
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
I'm fairly certain that Master Lift is a brand of gas spring. The ends are typically a ball and socket affair. There may be a keeper on the socket that keeps it from popping off the ball. If your helper or a prop is used to hold the bed up, you should be able to pry the keeper of and simple detach the socket from the ball and then lower the bed. It might be best to remove both springs to keep the bed from twisting. In addition to length, these springs have different working levels so your replacements should be the same else they won't offer enough lift assistance or will be so strong the bed won't stay down.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 07-05-2014, 06:58 AM   #8
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
Same thing happened on our 2014 25fb Int. I had to remove the gas struts in order to lower the bed.
Landrum is offline   Reply With Quote
Old 07-05-2014, 07:31 AM   #9
Well Preserved
1993 21' Sovereign
On a 2014 model, it should be under warranty. After y'all get done camping this weekend, give your closest dealer a call for them to take care of it.
bed storage gas struts "stuck" gbelcastro General Repair Forum 10 08-04-2013 09:25 PM
Over the bed light switch stuck AIR-Quarius Lights - Interior & Exterior 1 12-05-2011 02:55 AM
Screen door stuck in closed position ESCAPE POD Doors & Locks 4 10-31-2011 03:30 PM
Changing bed position in a 25' FB ocean Breeze Charlotte General Interior Topics 4 07-03-2010 06:27 PM
Sleeping position: Corner bed owners ericwarren Our Community 13 11-05-2008 07:15 PM
