Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 05-04-2007, 08:46 PM   #1
Nevada City , 95959
Help 25ft Tradewind possible 2 mid twins to full???
We would like to change our floorplan around without a lot of fuss. Tradewind 25 ft back bath middle twins? We would like a full bed or close to without using the front couch. Any ideas I am sure some of you have had to solve this puzzle? Also I need a line on new curtains. Thanks
lanajane is offline   Reply With Quote
Old 05-04-2007, 08:53 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Curtains: check out Silverthreads this foum in classifieds and also on ebay
Old 05-04-2007, 09:47 PM   #3
fastrob's Avatar
1976 25' Tradewind
. , Maine to Arizona
Same Boat
Our unit is configured the same.
We have the same dilemma.
Do you have more time than money and plenty of money? Are you a hands on guy? Clever and resourceful? Willing to tackle a long difficult job?
As I get closer to the rehab, meaning I have saved up $$$, it looks like a different trailer configured the way I want it will be cheaper.
As you read through the threads you will see the new one's are no bargain.
Some have terrible problems.
Mine has terrible problems. I love it!
There are some works of art and some frequently used treasures out there.
Check out jcfurguson's threads, there are many others; artists and craftsmen.
Hang in there.
R
fastrob is offline   Reply With Quote
Old 05-05-2007, 12:44 AM   #4
eikel1we's Avatar
1975 25' Tradewind
, Michigan
Send a message via AIM to eikel1we
The a/s's with a rear bath and center double have a gaucho on one side and a vanity flanked by closets on the other. I'm sure you could get dimensions to build those componets. Is there going to be a rally near enough for you to attend? You might find an a/s with that configuration to see in person.
I've seen pics with a futon replacing the gaucho. Of course, both gaucho or futon in the opened position would semi-block the "hall" until folded in the a.m.. Having mid-twins also, I think it might be an acceptable trade. We sleep very comfortably on a futon occasionally and the key is a GOOD futon matt.
sue and ike
'75 Tradewind - 25'
"Cupcake" air-912
2004 GMC Yukon XL 2500
Michigan - "middle of the mitt"
eikel1we is offline   Reply With Quote
Old 05-05-2007, 04:04 AM   #5
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Check out my my site, it may help.
Twins
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 05-29-2007, 05:18 AM   #6
ianrjam's Avatar
1978 25' Tradewind
London , England
Twins to double
We've had the same thoughts over here in London, England. Our Tradewind had centre twins. After a year of designing and redesigning, we thought that when touring it would be better to have a double bed that is out permanently so we don't have to fold down the front couch every night.
Our solution on the couch was to take out all the metal sheeting and elaborate shutters and bins and make simple aluminum legs so we can slide clear plastic storage boxed underneath that can be taken home in the car, stacked up at home, etc. The weight saving was good. We had new matress-type foam cut and recovered in plain fabric. It was a professional job done by a company who specialise in boat upholstery. It was expensive at around $1,200 in your money but it looks fantastic and is great to sit on and lie on.
We took the same approach on the twins. We are in the middle of this part of the conversion.
PROBLEMS
How do we avoid obstructing the route to the bathroom?
How do we keep underbed storage?
How do we keep weight down with a DIY solution?
How do we get back to twins if we find an unforseen problem or want to travel with family or friends?
What do we do with the space over the wheel arch on the other side?
SOLUTIONS
We cannibalized the aluminum strips and sections from the twins and designed a double that has a removeable section that can be unscrewed to go back to a twin. The rectangular hollow aluminum sections are strong and I can stand on the new structure even though I can pick the whole bedframe up with one finger! New plywood is cut in two pieces to the new shape. If we need a single, we just need to lay the original ply single back on. The legs are made of one inch square hollow section aluminum screwed to the floor with little brackets. We can slide 6 boxes underneath. As with the couch, we positioned the legs to suit the size of the plastic storage boxes we wanted to buy.
We made the double bed width 4ft6 but put a nice curve on the two outer corners so you can easily get past from the kitchen and the bathroom. When we sleep we don't use the corner of the bed anyway. Its a good compromise and is going to look curvy to match the Airstream.
We're going to buy a foam matress cut to shape from a paper template we will give them. We are looking for a nice American patchwork quilt to finish the job.
The opposite wheel arch is going to be boxed in as storage with doors on the front and a 1ft9 wide shelf at desk height for all those little things - the laptop computer, TV, camera, alarm clock, books, drinks, etc. which never seem to have enough horizontal surface in a trailer. There's enough space to put a small chair or two between the bed and the desk.
We work it all out on the computer so we don't have surprises but creating a 3D computer model of an Airstream is a bit of a challenge! It's good for testing shapes, dimensions and colours.
We are booked on to the England to France car ferry on July 27th so that's our deadline. We are behind schedule!!
Ian
ianrjam is offline   Reply With Quote
Twin rear beds DClark General Interior Topics 15 11-24-2002 08:49 PM
1972 Tradewind plentycrafty Our Community 2 09-20-2002 08:50 PM
'73 Tradewind for sale in Tampa Sneakinup 1970-79 Tradewind 1 09-20-2002 10:02 AM
Oddball '62 Tradewind? Mark in Modesto Airstream Motorhome Forums 0 09-08-2002 08:52 PM
