Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 10-06-2006, 06:01 PM   #1
1995 25' Excella
Istachatta , Florida
headliner replacement ?
What is the best way to clean off old foam and adhesive and install new insulating headliner or should this be left to an airstream dealer.
bikestreamer is offline   Reply With Quote
Old 10-06-2006, 08:04 PM   #2
Lacquer thinner does a great job for us.
Make sure that you have plenty of ventilation.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-06-2006, 09:43 PM   #3
maxandgeorgia's Avatar
1995 30' Limited
Ashland , Missouri
Do you have the "droopy ceiling" syndrome that so many of our mid-90's Airstreams have? Are you aware that as installed the headliner material extends back under the cabinetry in most cases? This complicates a simple removal, clean up, and replacement. You might do a search using the search tool found on the menu bar at the top of this page and read the various threads that have dealt with this all-too-common problem. You will find some photos of ceilings that have been improved by a variety of methods, some quite attractive, without replacement. Best wishes in finding a solution that fits you and your Airsteam. ~G
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
1978 Argosy Minuet, 6.0~Minnie/GPZWGN
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU
Go, Mizzou...Tigers on the prowl!
maxandgeorgia is offline   Reply With Quote
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Door Lock replacement? 3Ms75Argosy Doors & Locks 2 08-15-2002 11:12 PM
How do you repair cracks in the headliner of a 1985 325 Motorhome rdm General Interior Topics 3 08-03-2002 08:19 AM
Accordian Door Replacement Tamara Upholstery, Blinds, Walls & Interior Finishes 2 06-17-2002 12:08 PM
61 Bambi Panel Replacement 61BambiCanada Ribs, Skins & Rivets 0 06-07-2002 09:41 AM
