Old 05-02-2016, 02:28 PM   #15
Canal Flats , British Columbia
We have a headliner problem in our 94 diesel pusher. Wondering What size of screws should we use to hold up the headliner in a "quilted" pattern?
Grateful for responses fellow airstreamers!
patsy49 is offline   Reply With Quote
Old 05-02-2016, 02:29 PM   #16
What size screws did you use?
Old 05-02-2016, 04:05 PM   #17
2007 25' Classic
Hutto , Texas
I used 6 x 1/2 screws.
Wanderer2604 is offline   Reply With Quote
Old 05-03-2016, 08:24 AM   #18
Airstream deisel pusher
Thanks for all the info. Think we are going to go ahead and replace the strips going across AND do a screw quilt pattern in between with the 3/8 in screws. Wondering where y'all are buying your screws and caps??
Old 05-04-2016, 07:26 AM   #19
2007 25' Classic
Hutto , Texas
I used 1/2 inch screws but 3/8 should work well. You should be able to get the screws at any hardware shop.
The screw covers come in two parts. The clear part goes under the screw head when you put the screw in just like a washer with raised part up around the screw head. The white cover snaps on after the screw is tight. Most RV dealers and parts companies can get the screw covers. I did this fifteen years ago and I can't remember where I got them. If you are not near an RV parts retailer, you can easily buy them on-line. Type "RV Screw Covers" into Google.
I included photos of the labels of the screws and covers in a previous post. The screw covers come in more than one size but you can see which I used in the photo.
Good luck with your project.
tail droop in 27' models? jrousell 1972 Overlander 3 08-05-2011 09:23 AM
Rear Headliner nightmare (Bath headliner) Mrcrowley General Interior Topics 3 09-11-2010 07:35 PM
Frame Droop JackMac Repairing/Replacing Floor &/or Frame 7 12-06-2006 10:26 AM
Rear Bath Floor Droop bdbluegrass All Argosy Trailers 4 05-04-2005 08:44 AM
How do you repair cracks in the headliner of a 1985 325 Motorhome rdm General Interior Topics 3 08-03-2002 08:19 AM
