Old 06-27-2015, 03:04 PM   #1
2000 30' Excella
Monticello , Florida
Header repair
With the summer heat and poor original installation my header has peeled away from the ceiling. The plastic strip which is supposed to join both portions of the header does not catch the adjoining piece.
Any suggestions as to the glue that should be used to join the foam rubber to the aluminum ceiling? I have a piece of plastic header strip that I am thinking of cutting to slip it under the in-place strip and over the loose header thinking I might use rivets to hold it in place. any ideas on this approach?
07007 is offline   Reply With Quote
Old 06-27-2015, 05:37 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
"Header" the term used in building construction, is not used in aluminum monocoque construction, so could you post a picture as to what your question refers to, and I or someone else will most likely be able to answer you question.
Header Repair / Replacement T Reno Upholstery, Blinds, Walls & Interior Finishes 1 12-28-2013 02:21 PM
Header choices ALANSD Mechanics Corner - Engines, Transmission & More... 5 01-31-2005 02:07 PM
Smog Pump Removal & Header Info. 89_370LE Mechanics Corner - Engines, Transmission & More... 37 09-17-2004 02:55 PM
Header poll Astrodokk Airstream Motorhome Forums 14 10-01-2003 04:22 PM
