06-07-2009, 10:41 AM
2009 34' Classic
Edinboro
, Pennsylvania
Hanging flyfishing waders
Full timing compulsive flyfisher needs to hang and dry out gortex flyfishing waders on a daily basis. Does anyone have any experience with hanging waders to dry the interior and if so how have you done it? Want to use plastic "wader hangers" like you find in Cabelas. Where might be the best place on a 34' classic airstream trailer to install these? Appreciate any ideas!
06-07-2009, 10:51 AM
Vintage Alum. Enthusiast
1959 24' Tradewind
Phoenix
Unless its raining, I turn my waders inside out and hang them from the awning side rails. Takes little time for them to dry out. If its raining, I lay them over a lawn chair under the awning once they're inside out. You may have room inside your 34'er but I know I don't.
I've fished Spruce Creek a couple of times there in central PA and wish I could get back up there more often. Beautiful country.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
06-07-2009, 11:09 AM
2002 25' Safari
Dewey
I find that with the Gortex I do not need to turn these inside out as much as I did my old neoprene waders. I just hang them on the awning arm for an hour or so and they are dry. In the picture, you will see my waders on the rear awning arm. This was an outing with my fly club over Memorial Day weekend.
Check out the cute dog in the lower right corner as well.
Richard
06-07-2009, 11:46 AM
Belington
, West Virginia
Ditto on the "turn inside out." I too hang mine on the awning arm when weather is nice. In the tub when its not. I also have a pair of neoprene waist high boot foot waders which I hate. I stuff the boots full of newspaper to wick away moisture in these. Used on a daily basis you'd go through an awful lot of newspaper.
06-07-2009, 11:54 AM
2009 34' Classic
Coburn
, Pennsylvania
Excellent question. I have been wondering about the same thing because as a guide, I too need to keep the insides relatively dry and odor free as much as possible. While I agree that turning them inside out or merely hanging them over the awing support seem as reasonable solutions, hanging them by the boot foot to drain (after an unexpected "swim") and dry might be preferable. Unfortunately, it seems that the AS trailer interiors do not provide much usable space for installation of a wader docking mechanism like those boot/wader plastic hangers sold at Cabelas, Gander Mountain, Bass Pro etc.
06-07-2009, 12:00 PM
2009 34' Classic
Edinboro
, Pennsylvania
Thanks for the suggestions. Maybe there are still more creative options out there, particularly during winter steelhead fishing season. I agree that the limestone streams of Centre County PA are some of the best places to fish for wild brown trout.
06-07-2009, 12:18 PM
2002 19' Bambi
Lafayette
We spend considerable time fly fishing while living in our Airstream and drying our Goretex waders overnight is important. If you get back to the trailer at dark and temperatures overnight are below freezing, hanging them outside is not a useful alternative.
We have two sturdy hooks mounted on the shower wall and hang the waders, inside out, overnight from those hooks. In the morning, we put them with the neoprene booties in the flow of air from the furnace (not too close!) for a few minutes and they are absolutely dry for the day's fishing.
06-07-2009, 12:26 PM
Dewey
Yellowstone 2008
Brad, Richard and other flies...this picture is for you.
I saw this picture when Sue and I were returning from the Bozeman Rally. I truly thought of Brad and Richard as I shot this dedicated fly man doing his thing.
"Keep the road straight, the sky clear, the glass full, good friends and the laughter loud!", Pee Wee
06-07-2009, 12:28 PM
2009 34' Classic
Edinboro
, Pennsylvania
Tim,
Great idea. Tell me more about the hooks and how they are mounted. Are the screwed into the wall? Suction mounted? Brands you prefer for these mounts?
06-07-2009, 12:33 PM
2002 19' Bambi
Lafayette
The hooks we have are no longer sold or, at least, I have not seen them for sale for some time. Similar hooks are surely available.
Ours have a large back surface with double-stick foam adhesive to hold them in place. In addition, I drilled a hole in the center of the hooks' backs and used a screw as additional fastening to the fiberglass shower wall. If you do something like this, make sure that the hole you drill (for the screws) in the fiberglass is not too small. That way you can avoid chipping. I also used a dab of caulk to seal the screw hole.
