06-14-2014, 06:36 PM
2014 25' FB Flying Cloud
Rochester
Hanging a full length mirror
Hi all,
I have done some research on hanging a full length mirror on the interior of the bathroom door, but would I need more info before proceeding. There is not a lot of info out there.
Anyone ever try this? Success, or failure?
One option would be to use screws or clips, which I have ruled out as I do not want to screw into the hollow door.
Some have tried with Liquid Nails, but it would seem with little success.
I am hoping to use industrial strength Velcro and/or Museum Putty. Hoping to hear thoughts from others.
I am concerned that the adhesive on the Velcro may not stand up to heat or sub zero temperatures. I am also concerned that if it doesn't work, I may damage the door if I need to remove the Velcro.
I can't imagine that some haven't tried this. Care to share your thoughts?
-Carrie
If I only had a dollar for every time I got distracted, I wish I had a puppy.
06-14-2014, 07:50 PM
2020 30' Classic
2016 30' Classic
Covington
, Louisiana
We have used industrial strength command Velcro with great success for hanging pictures, wooden plaques, mirrors, magnetic boards, etc. we've had zero problems. Amazing stuff! Just make sure you use generous segments and get the "command brand" in locking style.
Hollis
, New Hampshire
I'd be tempted to use something like these...
Command Large Picture-Hanging Strips, White, 4-Strip - Picture Hanging Hardware - Amazon.com
In my sisters trailer, she tried the clips but they held the mirror too tightly and it cracked the first trip out.
My 60’s trailer had a full length mirror that floated loosely in a frame made of "U" shaped wood trim.
06-14-2014, 08:01 PM
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington
, Ontario
Originally Posted by LucaBluPlus2
Hi all,
2,
Your layout is slightly different than mine but I have had success mounting mirrors as follows:
I removed the small shaving mirror, and remounted it elsewhere in the head. I put a large 30" x 36" mirror in its place secured by double sided mounting tape and mirror brackets. The mirror also sits on the vanity so it's not inclined to fall down. I do not think you can have the mirror sitting on the vanity due to the placement of your switches. I also mounted a 60" long x 9" wide, thin mirror to the back of the wardrobe door using the same double sided tape and mirror brackets. Both mirrors have remained secured with no issues for two years now. You should be able to use the same technique on the head door, but with some risk, depending on the weight of the mirror. Over all, the combination of industrial strength tape and the mirror brackets seems to do the job. You could also add a tiny shelf for the mirror to sit on. I only mentioned the shaving mirror because it is such a poor (and cheap) resolution to a design issue that Airstream has completely failed at and it is my only complaint with the Airstream. (And I had to tell somebody) Jim
06-14-2014, 08:15 PM
2014 30' Flying Cloud
Ponce Inlet
We hung a full length mirror on the inside of the bathroom door with 4 command picture hanging strips. It falls off on really bumpy roads. It's been up for 6 months and has fallen 2 or 3 times. I added 2 more strips. I think I'll try the double sided tape if it continues to fall off.
We removed the shaving mirror, too, and replaced it with a 24 inch square mirror. It stays up fine with the command strips.
06-14-2014, 08:21 PM
2006 25' Safari
St. Augustine
I am surprised. Those things are really something when "locked in" I would think that the ones for 25 lb or so would do well.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
06-14-2014, 09:33 PM
2020 30' Classic
2016 30' Classic
Covington
, Louisiana
The locking command Velcro is incredible. We've had no issues with holding power.
06-15-2014, 12:15 AM
Rochester
Thanks everyone! I knew I couldn't be alone in this.
Here is the Industrial Strength Velcro that I have. Not sure what you all mean by "command" Velcro. Are you specifically referring to the 3M Command brand?
Do you suppose this would work?
-Carrie
06-15-2014, 12:29 AM
Rochester
oops no photo
Hmmmmmm, photo didn't take.
(How the heck do you add a photo?!)
Below is a link to the Velcro I am wondering about. Any thoughts on this brand?
http://i.walmartimages.com/i/p/00/07...18_500X500.jpg
-Carrie
09-17-2014, 09:36 AM
1982 31' Excella
Hemingford
, Nebraska
Like
09-17-2014, 09:45 AM
1986 32' Excella
Canton
, Georgia
We screwed a full length mirror to the outside of the slider on the bathroom of our excella. The screws went through the wood frame of the mirror.
