Old 10-31-2010, 12:04 PM   #85
VIKING's Avatar
Boulder Creek , California
It's been such a long time since I was able to do any work on the Safari that just seeing the long-neglected blog link in my signature line was getting to be a depressing reminder. When /if I do get back into it I'll bring back the blog also. Here's a link to it for your reference.
1964 Airstream Safari
I've also seen where an L bracket was welded or bolted onto the side of the frame and bolted through the c channel and floor to strengthen the area at the back. It just seemed easier to drill through the frame and c channel and run bolts right into the frame, rather than adding a bracket.
Best to you,
Rich the Viking
VIKING is offline   Reply With Quote
Old 11-09-2010, 10:05 PM   #86
Tool Hoarder
West , California
Wow! This looks familiar..... I have dreams about being as far along as you. I have also contacted Uwe about tanks. I think I am going out to see his shop sometime soon. He seem like a pretty cool guy. I wish I could go with the shell on option but the rear street support is completely gone. I have to re weld the entire rear end.
Keep up the good work, Ill be watching! Oh and thanks for posting pics, I had to jack a couple of the bathroom set up.
marzboy is offline   Reply With Quote
Old 01-09-2011, 08:21 PM   #87
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Progress!!!
Here I am today.It's hard to believe I had the interior stripped out at this point last year.
I am doing it right and no hurry ,although things are moving a little faster now.The pics show the first later of prodex and the styrofoam blocks to hold the top layer for the air space.Also pictured some one inch grommets I installed I got from VTS.Next is wiring!!!
ID:	119089   Click image for larger version
bwaysteve is offline   Reply With Quote
Old 01-09-2011, 08:29 PM   #88
x
XXXX , XXXX
Steve FANTASTIC. That's the cleanest inside of a shell I've ever seen. Absolutely beautiful installation of the prodex. Is the first layer glued right to the shell? Are you planning to seal the second layer with aluminium tape? I am planning to insulate with prodex myself. I have only done my belly so far and won't get to the shell until spring.
wasagachris is offline   Reply With Quote
Old 01-09-2011, 11:24 PM   #89
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Thanks!The Prodex is cut and sealed to the shell with an adhesive I got from Prodex.(case of 12 tubes)I ran out and am using Sealmate to affix the styrofoam strips which I cut from 1" 4x8 sheets 1" wide on my table saw.The job was super repetitive and boring after awhile.The top sheets when cut will fit into slots created from the 1"strips to make a tight fit.Not sure how much tape I will use.I did use it in places and seams on the first layer.I also used scrap as much as possible so I have very little waste(maybe 1 square yard so far) in little pieces.I received two rolls from Prodex(about 700 square ft.) and used 1 roll and maybe 5 ft. of the new roll .Time is lengthy as I work alone ,but the floor and the insulation are probably bigger jobs than anything else, so it should move along now.When I didn't have any money for the project I did polishing ,so 3/4 of the coach is polished already.I have done all the emblems ,beltlines,rub rails,and powder coated the vents for the WH and Furnace.
I got much inspiration from Ambie 64 and his shell off Ambassador redux.Check his posts.
Old 01-10-2011, 06:23 AM   #90
Ambie '64's Avatar
1964 28' Ambassador
Oklahoma City , Oklahoma
Well Steve, that certainly looks familiar! You're doing a great job! I agree with you on the sheer tediousness of doing the insulation, but you'll definitely be able to tell a difference in the finished system. Since I'm in holding mode, you've caught up with me and now I'm going to be following your lead on wiring. Keep up the good work!
Ambie '64 is offline   Reply With Quote
Old 01-10-2011, 12:36 PM   #91
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Hey Ambie,
Hope all is OK in OK.I was able to snag some great stranded wire from a Wire guy here in Irving I went to high school with.Got a decent price.I am thinking I may not have enough Prodex to finish the floor area,but mostly concerned about finishing the interior.I am ordering today a combo 45 amp convertor and breaker box from VTS.Melody Ranch has one and it makes the install much easier.I will tow over to his barn in Valley View to wire it when I finish the first layer in a couple of days.
That floor was full of bolts!!!!I also made some angle pieces to attach to the ribs for further strength as you did on the 64. Let me know when you are getting close to the Red River. Steve
Old 02-18-2011, 06:43 PM   #92
vhariable's Avatar
1967 30' Sovereign
1977 31' Sovereign
1988 29' Excella
Abilene , Texas
Steve I know I am a little late to this thread, but I am curious about your solution for mounting your tanks. Did I miss the details or could you provide some more information? I am looking at purchasing the same tanks and doing a very similar installation on my '67, while also adding a fresh water tank in front of the axles. How tall are the RV17 tanks?
'67, '77, & '88 Restoration Projects
http://projectairstream.com
vhariable is offline   Reply With Quote
Old 02-19-2011, 07:11 AM   #93
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
It's a Ronco RV H17 and hangs below the frame on one end 3".If you look at the pic in the catalogue it slopes from one end to the other. I am planning on fabricating a belly pan section to fit this.For freshwater between the rails you need an oblong tank.Uwe Salwender had one installed in a trailer at the Restoration Rally in ABQ last summer.You might go to area63.com and check his blog for pics.I have decided to install a larger tank behind the front couch.
Old 02-21-2011, 10:41 PM   #94
Breadbug's Avatar
1969 31' Sovereign
1975 25' Tradewind
Walnut Creek , California
Hey there. I'm a bit late with this question. I was reading back at the tanks installation and saw how you did the drains. Are you going exposed outside the belly with them?
I'm trying to finalize my floorplan so I can order tanks. I want to increase tank size and probably number too. 2 greys and an under floor black as well. Im pretty sure im gonna plum in a fill spout to the black tank to have as a flush too. I have a 75TW and am doing a shell off. Got it to the bones and I'm prepping for POR15. I've gotta get my plans done.
Any critiques welcome.
ID:	122853   Click image for larger version
Breadbug is offline   Reply With Quote
Old 04-27-2011, 12:25 AM   #95
Tool Hoarder
West , California
Hey Steve I have the same tanks. I am setting up the tank brackets and was wondering how much space did you leave between the top of your tanks and the bottom of the floor? Also it looks like you insulated your tanks, did you also insulate the floor between the tank?
Old 04-28-2011, 06:00 AM   #96
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
tanks
Did drains outside of belly and having a hat fabricated that will cover the remainder of the tank.
Old 04-28-2011, 06:04 AM   #97
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
tanks
I left about an inch.I did not insulate between as the insulation took up most of the space.Propabaly would though.
Old 04-28-2011, 06:20 AM   #98
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Steve,
Not sure if you've read my thread or not. Just wanted to say thanks for the tanks. I also used the Ronco 17H tanks on my Ambassador. I installed two gray and a new black tank.
That insulation installation looks awesome for sure. Nice work.
Lance
Top is offline   Reply With Quote
Ben and Lynn's Bambi II Re-do PA BAMBI II 1964 Bambi II 122 05-12-2017 08:11 PM
'68 Overlander ... Gutting Aluminati 1968 Overlander 12 02-23-2017 06:35 PM
Rescuing my childhood '62 GT ladypixie 1960 - 1964 Globetrotter 51 08-09-2013 03:09 PM
1961 Tradewind Custom dorchstream Member Introductions 5 05-07-2011 08:51 AM
Gutting Interior of '73 Sovereign kikileg General Repair Forum 1 04-01-2010 04:34 AM
