Old 07-19-2014, 05:36 PM   #1
clifandme729's Avatar
Gardnerville , Nevada
Goucho couch installation
I have a 1974 Overlander. The interior is in good condition, but the previous owner had removed the goucho sofa/bed. I purchased a Goucho sofa frame, but it now needs to be installed. It is simply the pull-out frame with the three openings for storage boxes. I am going to have custom cushions made for it, and I was able to obtain a diagram of how the cushions should be done. What I need help with is finding out how to properly install it. Does anyone have any information or experience with this? I am supernew at this Forum, so I'm not sure if I've posted enough information, and I don't really know how to post a picture - any help/advice would be greatly appreciated.
Thanks!
clifandme729 is offline   Reply With Quote
Old 07-19-2014, 06:07 PM   #2
2012 30' Classic
Homosassa , Florida
Terry, if you asking about installing the cushions, I can't tell you but if you asking about installing the gaucho to the floor I believe I can help with that. My couch has been removed by the PO. I bought a new couch and located the holes in the floor where the previous couch has been screwed to the floor. I used lag bolts on mine and everything lined up perfectly on the floor. As I located a hole, I stuck a piece of wire in the hole to measure where the next one should be. Hope this helps.
Tater is offline   Reply With Quote
Old 07-20-2014, 01:26 PM   #3
Thank you Jim for your comment. At the moment all I have is an aluminum/wood frame and I am trying to get information on how to attach it to the back (or front I guess) wall of the the inside of the trailer and also secure it to the floor. The floor isn't a problem, that's pretty straight-forward. Then I will have cushions made. I am just not sure how the back of the goucho/sofa/bed unit is attached to the trailer.
Old 07-20-2014, 07:29 PM   #4
2012 30' Classic
Homosassa , Florida
Hopefully someone with that arrangement will reply. Best wishes for a successful install.
Vent lift installation & Astrodome installation jessejane Roof Vents, Skylights & Fans 4 01-10-2014 04:34 PM
To couch or not to couch? Safari Tim Upholstery, Blinds, Walls & Interior Finishes 47 03-25-2009 02:51 PM
Couch/Goucho replacement in new Airstream norsea General Interior Topics 5 08-06-2008 09:28 PM
Couch Vs. Goucho higgy116 Cabinets, Counter Tops & Furnishings 3 05-12-2006 07:15 PM
Front Goucho-Bed JIMANDHELENE General Interior Topics 8 05-18-2002 01:10 PM
