Old 06-12-2012, 05:53 PM   #1
RLS
RLS's Avatar
2004 25' Classic
Longwood , Florida
Gas spring struts for mattress lift
I've been researching the spring struts for the bed lift and finally found some info. These are the Master Lift 1565SN 0400N 272/03 A2
ML 16-90 ones. Compressed length is 10.91", stroke 7.01", extended length 17.20" and 90 LBS. force. I replaced mine with these:
Replacement Gas Springs Per Pair - 17" Ext 110 Lbs Gas Spring - Maxum Hardware Very easy replacement and very much needed
Julia & Bob
W/ Neka & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 06-12-2012, 07:14 PM   #2
moderator
Central , Mississippi
We added a memory foam topper and the already-worn-out gas struts were useless...
An iffy set from the lift hatch of my Jeep Cherokee were close to the right length...
I moved one end mount a bit and they worked great
Hi Ho Silver RV!
Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
