Old 10-29-2007, 07:43 PM   #1
1978 23' Safari
High Mountains , Colorado
Freebies from Safari
After doing piecemeal refurbishments on several other vintage Airstreams, I'm going to dive into a complete gut job. The first order of business is to part out the interior cabinetry to make room for a completely new arrangement.
To be eligible for freebies, you need to be a supporting member of AirForums. Your only cost is shipping. PM me if you are interested.
The following items are available immediately:
Original water filter and original pump. Pump is not working, but I have seen other posts that claim these are refurbishable:
Name:	s_7339 water filter.jpg
ID:	48257Click image for larger version
Name:	s_7338 original pump.jpg
Over bed and over sink light fixtures with diffusers:
Name:	s_7333 over sink light.jpg
ID:	48258Click image for larger version
Name:	s_7334 bed fixture.jpg
Cabinet tambors. This cabinet is opposite the bed, under the window.
Name:	s_7331 credenza tambors.jpg
Roller drawers (5) that fit in the under window cabinet and five drawer glides and rollers. In addition, one extra roller the is salvageable.
Name:	s_7330 drawer glides.jpg
Tambors from under the front bed. This frame has an added feature of molded end caps.
Name:	s_7325 bed tambors.jpg
ID:	48262Click image for larger version
Name:	s_7326 bed end caps.jpg
Tambors from under the curb side couch. They are identical to the tambors above, but the frame doesn't have the end caps and the total frame is slightly shorter.
Name:	s_7324 couch tambors.jpg
Bed rail glides. A couple months ago I believe I saw someone in a tizzy looking for these.
Name:	s_7322 bed rail glides.jpg
more in next post,
Joe
averagejoe is offline   Reply With Quote
Old 10-29-2007, 08:31 PM   #2
1978 23' Safari
additional items that are available immediately:
Bed rail pullouts, 2 sets of four. One bed support frame is also available, but has been disassembled into its major frame pieces. If you want the whole assembly, you'd also get the glides from the previous post.
Name:	s_7315 bed pullouts.jpg
Flip up counter extension:
Name:	s_7316 flip up table.jpg
Under sink drawers:
Name:	s_7317 under sink drawers.jpg
Under sink large tambor, flip out compartment, and small tambor:
Name:	s_7318 under sink.jpg
ID:	48276Click image for larger version
Name:	s_7319 below stove tambor.jpg
Curtain divider and top support/glide. Unfortunately, there is a small 1/2" v-shaped rip in one fold.
Name:	s_7314 curtain divider.jpg
Joe
Old 10-29-2007, 08:40 PM   #3
1978 23' Safari
Soon to be available:
Three vent light diffusers and 3 vent lights. The switches all work and the knobs are the pull-off type, not the screw off type (the screw off knobs were from earlier trailers, like 1972 or so).
Name:	s_7327 vent light cover.jpg
ID:	48284Click image for larger version
Name:	s_7328 vent light.jpg
One original ducted vent. Vent crank works OK, but fan does not come on. This could be a microswitch problem or a dead motor or even a fuze--I haven't investigated that far. This vent has the translucent cover.
Name:	s_7329 ducted fan.jpg
Two original vents with solid aluminum covers. The cranks work OK.
No photo available.
Upper cabinets: The street-side cabinets and tambors that were originally over the kitchen and the closets will be available. I'm still having an internal debate about whether or how soon the curb side might be available.
Name:	s_7320 street upper cabinets.jpg
ID:	48282Click image for larger version
Name:	s_7321 curb upper cabinets.jpg
Joe
Old 10-29-2007, 08:56 PM   #4
1978 23' Safari
a couple more items that are worth mentioning:
In this photo taken from the bathroom door, you can see the small credenza on the left that has a flip-out drawer for the radio. The aluminum skeleton in the middle is one-half of a bed frame. Also, note the plastic window surround just forward of the no parking sign--that is most likely also going to be available. In addition, the eyebrow cabinet over the front window will also be available eventually.
Name:	s_7342 empty safari from rear.jpg
The under-bed "bins" are standing on end at the far end of the photo. These are practically impossible to pack and ship, so I cut them up and use them for out of sight patches and for other sheet metal needs. There are five of the larger brown plastic boxes that go in these bins.
The trash guys come on Monday, one week from now could be a deadline... (the elipses are for 2Air, of course).
Joe
Old 10-31-2007, 03:40 PM   #5
1978 23' Safari
It occurs to me that most of the "salvaged" items are tambours. Take a look at dmroot's elegant alternative--looks great, functional, and will last a lot longer than salvaged tambours.
http://www.airforums.com/forums/f420...1-a-31328.html
the trash man comes on Monday. I won't toss the tambours and small parts, but the frames and bigger stuff has to go.
Joe
Old 11-04-2007, 09:01 AM   #6
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
I would very much like ONE vent with solid aluminum cover - actually just the aluminum cover PLEASE please pleeeease How every you need to make it happen, that solid aluminum cover would save the day for me!!
EDIT: my '73 needs one solid overhead roof vent cover; I bet I misread the text-to-photo captions
Old 11-04-2007, 10:04 AM   #7
1978 23' Safari
Originally Posted by Wabbiteer
I would very much like ONE vent with solid aluminum cover - actually just the aluminum cover ...
I'll take a closer look today. I think the rear two vents are solid covers. the front one definitely has the translucent center window.
Joe
Old 11-04-2007, 12:30 PM   #8
Family Fun - Here we come
jeffnjen30's Avatar
1978 Argosy 27
Easley , South Carolina
we could actually use the other vent cover
if you think it would work on an Argosy. Also, just the cover. The PO said it blew off going down the road because they forgot to close it.
Thanks!
jeffnjen30 is offline   Reply With Quote
Old 11-04-2007, 02:51 PM   #9
1978 23' Safari
I don't know anything about Argosy lids, or much else [about Argosies] for that matter. If anyone else can help here, thank.
Here's the little radio cabinet, available with non-working cassette radio. You can just see that the formica band on the edge of the top needs to be reglued along part of its length.
Joe
Name:	IMG_7349 radio credenza-s.jpg
Old 11-04-2007, 10:12 PM   #10
ibedonc's Avatar
1983 31' Excella
Caldwell , Texas
Hello I have a 83 31'er rear bath that I need a few things
curb side center bunk , top tambors right hand end cap
the Curtain divider
ibedonc is offline   Reply With Quote
Old 11-05-2007, 06:43 AM   #11
bertro's Avatar
1971 23' Safari
Groveport , Ohio
Hello, I would love to have the counter extension and water pump.
bertro is offline   Reply With Quote
Old 11-06-2007, 08:27 AM   #12
1978 23' Safari
I'll sort out all the requests, both PM'd and here, and get back to everyone this weekend. Gotta hit the road for a couple of days.
Joe
Old 11-12-2007, 05:08 PM   #13
1978 23' Safari
Here's how everything shakes out. I'll pack them up as soon as I collect enough cardboard.
Under sink tambours --SGIST32135
Kitchen and Bedroom lights --Kevin245
Filter and Pump -- Excella CM
Pop up table -- Silver Threads
Goucho tambours --Overlander63
there are a few things I haven't gotten around to:
vent cover -- Wabbiteer, I just haven't remembered to check. Ditto Jeffnjen30, I think there are two solid vent covers.
lights -- Bob Fowler, you're in line for the lights from the Ambassador, if it gets parted out (see http://www.airforums.com/forums/f173...dor-37519.html)
upper cabinet end caps -- Coastalview, there are two end caps in the Ambassador, so same deal, if it gets parted out. Ibedonc, I haven't decided about the upper cabinets in the Safari, but you're first in line for and end cap from the Safari upper cabinets if I take them down. Did you want tambours, too?
Pop up table -- Bertro, there is a pop-up in the Ambassador. I'll keep you in mind.
Joe
Old 11-12-2007, 05:13 PM   #14
1978 23' Safari
Here's an item I discovered today when I pulled the water heater. The electric heat controller seems totally intact and when switched on it loaded the generator, so I think the heating element still works. I have no clue about the element's condition, but I'll pull the whole thing out of the tank if someone needs it.
Name:	IMG_8198 water heater controller-s.jpg
Joe
Freebies... sorta Safari Zeppelinium Cabinets, Counter Tops & Furnishings 53 08-12-2010 07:40 AM
Freebies... sorta Sovereign Zeppelinium Cabinets, Counter Tops & Furnishings 51 11-20-2007 01:46 PM
Southwest Southern California Freebies ?? mcrickc Boondocking 11 03-07-2007 10:52 PM
Doing research-19' Bambi-Safari OR 23' Safari-WHY? ernesto ca Member Introductions 9 04-06-2006 06:33 AM
