Old 07-09-2016, 10:35 AM   #1
1970 31' Sovereign
Lynn Center , Illinois
framing
We are going to begin interior framing in our Airstream. Do we use the standard 2x4's or do we need to order something different? We are going to be building custom cabinets, bathroom, bed, etc.. Advice?
We also are getting this toiletometic 310 Series Standard Height Toilet, White. Is this a good toilet for everyday living?
Thank you.
cdmeece is offline   Reply With Quote
Old 07-09-2016, 03:02 PM   #2
DFlores's Avatar
1968 22' Safari
1x2 is the heaviest framing we put back in ours, using existing as a pattern. We used a 1x3 for reinforcement when redoing our bed frame.
Sent from my iPhone
David & Diane
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 07-09-2016, 03:32 PM   #3
fran&frank's Avatar
2016 27' Flying Cloud
Hartsburg , Missouri
Not sure what you would be "framing" that would require 2X4 dimensional lumber. You want to be thinking more in terms of cabinet construction using 1/2 or 3/4 inch plywood or building panels with stiles and rails made from 1x2 to 1x4 boards and plywood or solid wood panels.
Frank & Fran
2016 27' FC FB with 400 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
fran&frank is offline   Reply With Quote
Old 07-09-2016, 04:44 PM   #4
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
2X4s are definitely overkill.
I rebuilt everything front of the bedroom and using a combination of hardwood and softwood cabinet frames covered with 1/8 and 1/4 inch hardwood veneer plywood. 3/8 inch AC ply for the seat bottoms and 1/2 AC for countertops.
Hopefully you have saved the wall partitions and channels riveted to the walls. 1/4 inch ply fits snugly in the channels and eliminates the need for framing the back side of the cabinets.
Good luck,
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 07-09-2016, 05:12 PM   #5
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
framing
I used 3/4" or 1/2" plywood cut long way into strips of 1", 1 1/2", or 2" depending on the task at hand.
It is light, strong, and stable.
Superat stultitia.
Framing for New Water Heater Opening silver-man 1960 - 1964 Overlander 3 04-25-2011 11:17 PM
framing issues on vintage airstreams dmand001 Repairing/Replacing Floor &/or Frame 2 10-14-2010 04:10 PM
Framing with 5" channel - outrigger source JoePfznik Repairing/Replacing Floor &/or Frame 3 02-14-2009 03:56 AM
Framing out 60x80 bed LI Pets General Interior Topics 29 11-30-2006 09:30 PM
AC hole cut-out framing silver 67 Furnaces, Heaters, Fireplaces & Air Conditioning 8 10-05-2006 10:53 AM
